Go to Post Blue Nitrile Tread is the best smelling wheel tread. #thingsyoufigureoutat2AM - Ginger Power [more]
Unread 13-01-2006, 21:09
Andrew Blair's Avatar
FRC #0306 (CRT)
Mounting the MiniBike CIM
What are people's plans for mounting the large CIM? I thought I'd try and get some professional opinions , instead of " if the setscrews don't hold, we'll use some zipties". Maybe Andy Baker can elaborate (or anyone who owns the part) on how they mounted the motor.
-Sir Francis Bacon
-Albert Einstein
Unread 13-01-2006, 21:44
ryan_f ryan_f is offline
ryan_f is an unknown quantity at this point
Re: Mounting the MiniBike CIM
I think he clamped the actual motor to his gearbox, and then used that protruding screw to stop the motor from turning itself (drilled a hole into the metal for it to fit into it. Mind you, that's what I THINK, that doesn't mean that that's what he actually did
Unread 14-01-2006, 22:20
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
There are CAD files and an assembly procedure for the "Upgrade Kit" at www.andymark.biz.
I hope this helps.
Andy
Unread 14-01-2006, 22:36
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
I'm drilling a .190 hole in that tab sticking out and leaving about .11 of radial meat. Then using the remaining stud for the other mount point. Although I'm using the motor for a ball shooter, which won't see much torque. If you wanted to mount it in a transmission I'd recommend replacing the shorter bolt with one another 1/2"-3/4" longer maybe, and then also using the tab to drill out a 3rd. Just for those big torque spikes and vibration. But it may be fine with just 2 bolts and a good torque on the fasteners.
www.179swampthing.org
Unread 14-01-2006, 22:39
FRC #0306 (CRT)
Thanks! I really like that mounting connector. I wanted to make sure that my mount wouldn't explode halfway through launching a ball. Messy...
-Sir Francis Bacon
-Albert Einstein
CIM Motors UlTiMaTeP Motors 13 10-01-2006 14:48
6 CIM Motors? psquared89 Kit & Additional Hardware 16 09-01-2006 08:47
CIM speed in reverse? colt527 Motors 41 06-12-2004 19:09
CIM vs. Drill motor duckshepherd Motors 3 15-02-2003 18:36
Cim Mounting Thunder360 Motors 8 28-01-2003 10:11
