Go to Post There is no such thing as reading too much into things. Such ideas are blasphemous in nature! - Guppy294 [more]
Unread 14-01-2006, 16:47
sheyna's Avatar
sheyna sheyna is offline
FRC #1748 (Lab Rats)
sheyna is an unknown quantity at this point
CMUCam pan and tilt
Ok i changed all of the settings so that the camera can find the object but when it tries to track it and move it in the center it goes off of the page. the tilt works perfectly but the pan goes left instead of right and right instead of left. i been working all day and i need some major help because i am going to go insane .
~sheyna
Unread 14-01-2006, 17:00
Re: CMUCam pan and tilt
Are you using LabView, or testing straight from the RC?
Unread 14-01-2006, 17:14
iBheat's Avatar
iBheat iBheat is offline
FRC #0418 (Lasa Robotics)
iBheat is on a distinguished road
There is a jumper on the camera board that allows you to reverse the servo direction!
Go to: http://ifirobotics.com/camera.shtml and download the Camera Board Markings.zip file and it is in the CMU Cam Assembly.pdf on the right side!
Unread 14-01-2006, 20:43
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Which jumper do I remove? My team has been having the same problem and on the pdf there are two jumpers... The Internal Power to Servo one and the Oscillator Connect.
I am guessing we remove the latter, but would not this reverse both servo directions, failing to correct anything? Thanks =/
Unread 14-01-2006, 21:06
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Don't remove either. You have to add a jumper. If you look at the doc's, there a "Pan Reverse" and "Tilt Reverse".. you need to put a jumper on whichever you need (You can pull a jumper off any old computer, or old speed controller)
Also, this will only work if you use the CMUcams servo outputs (I think)
Unread 14-01-2006, 21:43
.999~=1
Ah yeah thanks, I see it now. Someone else also just pointed this out to me @.@ I can't believe I didn't see that...
Unread 14-01-2006, 22:17
Bharat Nain's Avatar
You can also change the direction in the code where
#define PAN_ROTATION_SIGN_DEFAULT -1
#define TILT_ROTATION_SIGN_DEFAULT 1
in tracking .h
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 14-01-2006, 23:07
iBheat's Avatar
I also agree with devicenull in saying that jumping the jumper will only work if you have the servos controlling the pan and tilt connected to the camera board. But if you are connecting it to the RC and using the code written by Kevin you will have to edit the code (in tracking.h) that Bharat Nain posted in the post before this!
Unread 14-01-2006, 23:11
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
We had to add a jumper and change the direction in the code in order for our camera to track properly.
"The important thing is not to stop questioning. Curiosity has its own reason for existing. One cannot help but be in awe when he contemplates the mysteries of eternity, of life, of the marvellous structure of reality." ~Albert Einstein
DHSE '06, PSU '10 (Eberly College of Science - Chemistry)
Unread 14-01-2006, 23:20
sheyna's Avatar
oh aight thank ya'll
~sheyna
LabVIEW - CMUcam finds target but cant track bear24rw Programming 6 13-01-2006 21:43
2 (hopefully) easy CMUcam questions. Validius Programming 0 30-12-2005 22:42
Tilt Troubles Mumford 406 Programming 4 29-03-2005 22:19
Dashboard View of Pan and Tilt Servo Values JoeXIII'007 Programming 1 02-02-2005 22:34
