Go to Post This thread is going to make me spend my entire tax return on multitools. - Lil' Lavery [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 14-01-2006, 23:25
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
Re: do tracks and wheels together make a better robot?
http://myweb.wit.edu/cuffiim/robotics.wmv
http://myweb.wit.edu/cuffiim/robotics2.wmv
http://www.chiefdelphi.com/forums/sh...0&page=2&pp=15
this came up in this thread.
To say you have not seen tracks done right you have not been looking.
you will see a 6 wheel robot trying to push us. they had a six motor drivetrain
So track done right will be fast, turn quick and be very powerful
Building FIRST robots since 1995
BVT Robotics
Unread 15-01-2006, 00:11
Originally Posted by Sean Schuff
Yes but can you climb the ramp AND get onto the platform that way?
...There are two options to solve this dilemma: a) tracks or wheels all along the lower drive section of your robot or b) an area between the wheels that allows for the transition from the ramp to the platform.
and a 3rd option: inertia !
Unread 15-01-2006, 00:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Originally Posted by sanddrag
If you do it correctly, you can get away with as little as 2mm clearance for 6wd. Of course that doesn't allow for wheel wear or running over dropped bolts or anything.
Yes but can you climb the ramp AND get onto the platform that way? My guess is "no".
Guess again. You most definitely can. The trick is in carefully analyzing how the robot gets up the ramp and onto the platform. It is all in the weight distribution. If you get it right, your clearance can be next to nothing. The end that goes up the ramp first needs to be a bit heavier. We'll call the end that goes first the "front." See, when you go up the ramp, when the front wheels pass that edge between incline and flat surfaces, the idea is for them to keep going along the imaginary incline in the air and not touch down on the platform. The, once the center wheels have reached the edge between incline and platform, then you want the weight in the front to pull the front wheels wheels down (and the back wheels up off the ramp). You'll never get hung up between the front and center, or center and rear wheels, if you get the movement right. With proper weight distribution, it is very achievable.
Unread 15-01-2006, 00:42
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The only problem with this strategy being that unless your wheels extend beyond the end rail of your frame, with 2mm of clearance you'll grind the edge of your frame into the ramp before the wheels contact the ramp surface
2001-2004: Team 100
2006-Present: Team 254
Unread 15-01-2006, 12:13
Sean Schuff's Avatar
Sean Schuff Sean Schuff is offline
Year 18 in FRC!
FRC #0093 (N.E.W. Apple Corps)
Sean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond repute
No matter how you configure it or how you distribute the weight, you will, at some point, high side your robot without the proper ground clearance. The only thing that will keep you from STAYING high sided, as Ken pointed out, is inertia. The only thing that will accomplish what you have described is a shift-on-demand center of gravity (CG).
A six wheel design (two front, two middle, two rear) still has points in between the wheels where the frame can, and if not designed properly, will contact the transition edge from ramp to platform. 2mm of clearance will not allow for the proper clearance and your CG will not shift at the right point.
With regards to your CG you've got three realistic options: in between the front and middle wheels, directly over the middle wheels, and in between the middle and rear wheels.
If your CG is in between the front and middle wheels your robot will high side itself in between the front and middle wheels as it makes the transition from ramp to platform.
If your CG is directly above the middle wheels, as your robot moves onto the ramp it will shift back to between the middle and rear wheels until the robot is on a level surface again. As the robot transitions from the floor level playing surface to the ramp, the CG will shift to the rear of the robot. Once this happens, the CG will stay between the middle and rear wheels until it is horizontal again. Since the rear wheels will have to make the transition from ramp to platform to accomplish this, the high siding will occur between the middle and rear wheels.
If your CG is in between the middle and rear wheels, your robot will high side itself in between the middle and rear wheels as it makes the transitions from ramp to platform.
Obviously there are other variables in this equation. Ken brought up inertia as being one way to overcome the need for adequate clearance but then you need enough inertia to overcome the friction between your robot frame and the ramp/platform ridge. Another variable is going up the ramp at an angle versus perpendicular to the incline. This may allow you to lower your clearance if designed properly.
For a simple topic about tracks versus wheels this has become a very detailed discussion. I love it!
Sean
Every child. Every program. Everywhere.
Thanks Plexus Corp. for two decades of partnership and counting...your company gets it!!
www.nacteam93.com | Tesla Engineering Charter School
Unread 15-01-2006, 12:19
I didnt mean inertia as in scraping your way over the edge with sparks flying everywhere
I meant as in "an object in motion tends to stay in motion (in the same direction)"
in the 2002? game, with the containers and the center ramp, teams needed to be the first ontop of the ramp in auton mode. As a result many bots were airborne as they came off the upward ramp.
THAT kind of inertia ! :^)
Unread 15-01-2006, 13:48
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
that was 2003 (Stack Attack). I know of at least one robot (Crabgoat, Team 190) that had their auto mode programmed to right their robot, as it had a tendency to flip over opposing robots when going over the top. Fun to watch!
Unread 15-01-2006, 14:02
Year 18 in FRC!
Imagine the surprise on the faces of the drivers, operators and coaches as your robot went airborne off the ramp! Sweet butta!
Unread 15-01-2006, 14:43
no surprize - if your bot is going uphill then it MUST get airborne when the angle of the ramp changes suddenly.
The question we all had to calculate was 'how airborne'. If you went fast enough it was possible to fly over the top of the ramp completely, and land on the other side.
Most bots only got a couple inches of air.
Unread 15-01-2006, 17:54
gondorf's Avatar
gondorf gondorf is offline
inventor/solidworks engineering spe
AKA: stephen truscott
FRC #1733 (The Polar Bots)
gondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to behold
so just drawing a conclusion from these answers yes treads do help if you have a shooter, it does increase ball accuracy, and it helps to get the robot up the stupid ramp that is impossible from my teams perspective.
*** writes note to tell team to use treads***
Unread 15-01-2006, 19:17
Year 18 in FRC!
Don't limit yourself to just treads. They are an elegant solution to the problem if you can implement them well. I have seen quite a few teams who have done a bang-up job with treads. Just look through some of the pictures pages for past competitions and you will see what I mean. But that doesn't mean that it is the only solution to the problem. Remember, one problem, 1,000+ teams and 1,000+ different solutions to the same problem.
You can accomplish the same accuracy with wheels it just requires the appropriate implementation of them.
Good luck!
Unread 15-01-2006, 21:24
occra 23.
AKA: ryo
None #1481
we were talking about tank treads that do not have idler wheels. The photos posted in this thread are the 1st bots Ive seen that do have idler wheels (the right way to use threads)
un-necessary 3 motor designs are designs that dont need 3 motors on each side -it depends on what else the drive train can do. If a bot can spin its wheels against a wall, then putting more motors on it does nothing but spin the wheels faster
and spinning the wheels faster does not give you any additional pushing force.
[Ken hides back under his desk :^) ]
but it lets you gear higher and = faster top speed. depending on how well you can control it.. but same with cars. who needs a car that goes 200mph... but people still buy because it has a high top speed. the potential. and just because they can... which we cant.. boo
Unread 15-01-2006, 23:48
Jay Trzaskos's Avatar
Jay Trzaskos Jay Trzaskos is offline
Jay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond repute
http://firstrobotics.uwaterloo.ca/dr...insgallery.php
Take a look around on this site to see how tank treads have been implemented over the years. Actually, this is a great resources for any part of your robot.
JT
229
Jay Trzaskos
Product Design Engineer
University at Buffalo - MAE 2012
Alumnus - Theta Tau, Mu Gamma Chapter
Unread 16-01-2006, 13:56
gondorf's Avatar
tank treads may be a good thing for a robot but they are a pain to make.
from how i tried to do it tank treads are sort of like 4 wheel drive with a chain connecting it.
my team is having trouble with just 4 wheel drive, let alone a tread
Unread 16-01-2006, 14:02
FRC #0061
Rookie Year: 1995
http://www.valleytech.k12.ma.us/robo.../2004VIEW5.jpg
http://www.valleytech.k12.ma.us/robo...2004track3.JPG
This is hard ? It is pretty easy to do. with BrecoFlex pulleys and timing Belt
BVT Robotics
Old NASA robot for sale Greg Needel Chit-Chat 4 10-11-2005 10:45
Who Likes Wheels? Rob Technical Discussion 22 06-05-2004 23:49
Tank tracks vs. Wheels MBosompra Technical Discussion 28 16-01-2004 23:31
Tank treads and specialty wheels archiver 2001 7 24-06-2002 01:25
