Go to Post Dave Lavery just responded to one of my posts. I think that I might die. - Karibou [more]
Unread 14-01-2006, 14:42
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
Reasonable Speed
What would be a reasonable speed for a 120 pound robot to pass 54 feet?
Unread 14-01-2006, 14:56
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Reasonable Speed
Four seconds
If you agree there is acceleration and deceleration, then around 18 fps might be a good number. Consider controllability - 100 fps is possible, but would it be good? OTOH, 5 fps would be very powerful in a pushing match...if you could get there before the match ends.
You need to find out from your strategy folks what you need to accomplish, and set a speed based on that, not SWAG.
Don
Unread 14-01-2006, 15:45
wilshire's Avatar
wilshire wilshire is offline
OSNAP. a gear flew out of the robot
wilshire is just really nicewilshire is just really nicewilshire is just really nicewilshire is just really nice
Send a message via AIM to wilshire
At IRI concerning drive trains to be used in a FIRST match Bill Beaty he said that a good speed that is just below where your driver may have problems controlling the robot would be around 10-12 fps. I agree with him on this because once you have your robot going above this speed your driver may have problems controlling the bot especially if your drive system is not fine tuned. It also could cause problems when your bot has a high COG and you would like to turn pretty quickly. Well as physics dictate, that maybe hard to do without having your robot fall over on its side. Just some things to think about.
AIM: wilshire461
Purdue FIRST Teams
Team 461 -http://www.boilerinvasion.org/
Team 1646 - http://www.precisionguessworks.org/
Team 1747 - www.harrisonboilerrobotics.org
Unread 14-01-2006, 16:23
Brandon Holley's Avatar
a good, solid, general fps to go by is around 11-12...you should have reasonable power w/ quick speed
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 14-01-2006, 18:40
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
One other important point to remember if you are using very high friction tire material or if you are planning to "skid steer", ratios that result in ~8 ft/sec or higher can cause your motors to stall or run at a very high current before the wheels spin. This can be very bad because it can cause your circuit breakers to trip or, if the motors get too hot, they can stop working as well.
Unread 14-01-2006, 18:56
Best Available Data
FRC #1778 (Chill Out!)
Are we talking shifting or not shifting? If your robot moves at 12fps, as others have indicated, your driver will have a field day attempting to make those minute direction changes. It's really hard. 5 fps is definitely way to slow, as you'll probably get within scoring range when your offensive period ends! I'd say somewheres in the 7-9 fps range. Which makes it about 6 or 7 or so seconds.
Unread 14-01-2006, 23:38
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
I think our robot will end up being around 11-1 to somewhere as low as 7-1 using the cims
Unread 14-01-2006, 23:45
Stephen P's Avatar
Stephen P Stephen P is offline
Stephen P has a spectacular aura aboutStephen P has a spectacular aura about
The kitbot gearboxes generally give the robot a good balance of speed and power, if a little on the fast side. But you can always fix that in the code
You know you are an electrical engineer when you can determine voltage relative to pain with a 5% error.
Unread 14-01-2006, 23:54
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
Last year, we could achieve 14 fps going full throttle, and if pushing something, well, we managed to push a robot running skyway wheels sideways across the arena at maybe 4-5 fps. So, it's not always a complete tradeoff between power and speed. 2 motors in each of those kit gearboxes can be mighty powerful if they power 7 inch wide drive wheels with conveyor belt material treads.
Unread 15-01-2006, 00:09
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Power is relative (in the pushing sense. Obviously mechanical power is absolute).
While you may be able to push a great deal using the kitbot with 4 motors, relative to another robot using the same setup, your robot is not powerful at all.
So as long as you're facing a robot that's 1)using fewer motors than you or 2) is using the same amount of motors but geared to go faster, your robot will be relatively powerful.
2001-2004: Team 100
2006-Present: Team 254
Electronic Speed Controllers for DC Motor Spindle Robotics Education and Curriculum 12 23-04-2005 09:18
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
Joining 2 dif. motors K.Shaw Motors 32 14-10-2004 19:40
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
