Go to Post Y'know... I think I'd much rather have big balls than hang myself... - FotoPlasma [more]
Unread 13-01-2006, 22:38
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
MAX ball shot trajectory
I know that most teams must be working out the math as to how far they actually can shoot the ball with a 12 m/s speed
I'm sure that people are also playing around with the concept that if you are moving forward when shooting you will have a faster speed and hence longer trajectory
However, I believe that if you are really planning on shooting the "long shot" your not gonna want to be moving because even if you can shoot it really accurate standing still once you move there will be almost no accuracy.
So who has figured out the ideal angle and hence the maximum trajectory?
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 13-01-2006, 22:44
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: MAX ball shot trajectory
Part of that depends on what height your shooter is at. We were originally planning on a higher shooter, I was getting that with a shooter 54" off of the ground shooting the ball at 12 m/s at a 45 degree angle, you would be able to land the ball in the goal from just under 45', without air resistance. With air resistance my guess is the maximum range will be somewhere within a few feet of 40'.
Unread 13-01-2006, 22:50
racsan12345 racsan12345 is offline
FRC #1351
racsan12345 is an unknown quantity at this point
For launching 4.5 feet to 8.5 feet:
Please input the initial velocity in meters per second: 12.8
Please input the coefficient of drag (0.07 - 0.5): 0.416
The uber best range is 14.7775 meters at an uber angle of 47 degrees.
For more calculations refer to my
C++ Code:
#include <iostream.h>
#include <math.h>
int main()
// float i = cos(x); x is in radians
// float i = atan(x); i is in radians arctangent
float x;
float y;
float v_initial = 12.8;
float v_x;
float v_y;
float initial_angle;
float theta;
float drag;
float area = pow((3.5 * 2.54 / 100), 2) * 3.14159;
float mass = .206; //kilograms
float C_D; //Coefficient of Drag
float a_x;
float a_y;
float increment = .01; //Incrementing time
float best_range;
float rad_conv = 2.0 * 3.14159 / 360.0;
float uber_best_range = 0;
float uber_angle = 0;
cout << "This program will calculate the maximum range and best angle to launch a 7 inch diameter poof ball." << endl << endl;
cout << "Please input the initial velocity in meters per second: ";
cin >> v_initial;
cout << "Please input the coefficient of drag (0.07 - 0.5): ";
cin >> C_D;
for(initial_angle = 10; initial_angle <= 80; initial_angle = initial angle + .5)
x = 0;
y = 0;
v_x = v_initial * cos(initial_angle * rad_conv);
v_y = v_initial * sin(initial_angle* rad_conv);
best_range = 0;
do
theta = atan(v_y/v_x);
drag = .5 * C_D * area * sqrt(pow(v_x, 2) + pow(v_y, 2));
a_x = drag / mass * cos(theta);
a_y = drag / mass * sin(theta) + 9.8;
v_x = v_x - a_x * increment;
v_y = v_y - a_y * increment;
x = x + v_x * increment;
y = y + v_y * increment;
if(y > 1.3 && v_y < 0) //To change height difference, change the 1.3 (meters).
best_range = x;
}while(y >= 0);
cout << "At " << initial_angle << " degrees, the best range is " << best_range << " meters." << endl << endl;
if(best_range > uber_best_range)
uber_best_range = best_range;
uber_angle = initial_angle;
cout << "The uber best range is " << uber_best_range << " meters at an uber angle of " << uber_angle << " degrees.";
return 0;
Unread 13-01-2006, 22:56
The Arizona Mentor
AKA: Andrew
Why are you using a starting velocity of 12.8 m/s? I believe we're limited to 12 m/s.
Unread 13-01-2006, 23:17
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
Racsan, your calculations dont make sense
once the ball reaches maximum trajectory, drag DECREASES ay not increases it.. so the plus sign there doesnt make sense.. you need an if statement.. if vy is negative, then change the sign on drag.
Anyway my data say
.798 radians at 9.97 meters launched at 12 m/s
The only simplifying assumption I made was that
drag in x direction = dragcoef*vx^2 rather than taking the sine of the drag.. its accurate enough I believe.
Tatsu
Unread 14-01-2006, 08:52
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The easiest way to figure the direction of the drag is Fx = Fd * Vx / V, actually. You need all those numbers anyways. Back on the topic of the thread, though, I get a maximum range somewhere around 30 to 35 feet depending on your Cd assumptions. It's all terribly approximate because our ball might be rough enough for the Cd to start at .2 when the ball is traveeling 12 m/s. Then jump up to .416 as it slows down.
Unread 15-01-2006, 00:02
FRC #1351
Tatsu
Tatsu,
When v_y is negative, it makes atan(v_y/v_x) makes theta negative, thus making sin(theta) negative. So you wouldn't need that if statement.
Unread 15-01-2006, 02:10
binary_sandman's Avatar
binary_sandman binary_sandman is offline
AKA: andrew sweet
FRC #1388 (Eagle robotics)
binary_sandman is infamous around these parts
shooting the ball into the top goal is very Probable the ball itself is 7in the goal is 40in more tham 4 times the size;
traveling at 11.9meters per second to be safe;
39.041984feet per sec which can be made from the middle of
the field (in theroy).
conclude this there is a good chance this will work esp.
we have already programed Autonomous and most of
drive motors
{1388 all the way}
Unread 15-01-2006, 12:59
racsan - agreed. sorry, my mistake
Unread 15-01-2006, 18:27
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
45 degrees is the angle that will give you the greatest maximum range from the goal, but that's is not the only factor to be considered. Because the goal has a top there is a period where you cannot shoot, as your shot would be hitting above the goal at that point. Also, because of the wall there is a period where your shot will hit the wall before it can get high enough to pass through the goal.
Thus why I suggest a variable angle.
Unread 15-01-2006, 18:36
ThomasP's Avatar
ThomasP ThomasP is offline
FRC #1255 (Blarglefish)
ThomasP is just really niceThomasP is just really niceThomasP is just really niceThomasP is just really nice
Send a message via AIM to ThomasP
You don't need variable angle to get a better range of shots, you can have variable force to have the same effect.
Unread 15-01-2006, 19:26
in between teams
AKA: Luke Van Oort
Although this isn't entirely on topic, make sure that you don't end up too far above the minimum. The goal slants forwards just a little bit, so any power over what you need to score it and it'll smack the top of the goal and fall onto the platform.
Team 1219: 2009 - Mentor
Unread 16-01-2006, 00:15
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
I wouldn't bother with computations of drag. At 12 m/s with a circular ball flung by some mechanical system, the influence of drag is probably not going to be distinguishable from other sources of variation.
Why not just do some basic calculations with pencil and paper and then make a spreadsheet. All you really need is basic physics:
v = initial_velocity + at d = vt + .5*a*t^2 quadratic formula.
(OK, you need sin and cos of your angle too.)
A perhaps more interesting question than what is the farthest a ball can be thrown is what is the minimum angle of elevation required to get the ball into the center goal at all?
Example:
Assume an initial "muzzle velocity" of 12 m/s and an angle of 20 degrees:
Upward velocity = 12 * sin(20) = 4.104 m/s
So what is the maximum height above the gun this ball will reach?
Well it will reach this max height when v = 0, so:
0=4.104 - 9.8t
9.8t = 4.104
t = 4.104/9.8 = 0.419 seconds
d = 4.104*0.419 + (.5)(-9.8)(0.419^2)
d = 1.719 - .860
d = 0.859 m = 33.8 inches
When you release the ball, remember that no part of the robot can be above 60 inches. So the bottom of the ball at the release point may be well below 60 inches. But let's assume the top boundary condition of a release at 60 inches.
60 + 33.8 = 93.8 inches = 7 ft 9.8 inches = well below the goal.
Unread 16-01-2006, 02:13
b_mallerd b_mallerd is offline
Programmer
FRC #1346 (Trobotics)
b_mallerd is on a distinguished road
Send a message via MSN to b_mallerd
If you've done any of those physics labs...you'll find that theoretical physics is only a very rough approximiation of the actual answer. I think you can use the formulas for a rough starting point but guessing and testing is probably the best way. These balls are so light that if there is spin on it...there is going to be a major trajectory change anyways. Ever see a ping pong ball with back spin? It flys very wierd.
Unread 16-01-2006, 10:02
mathking's Avatar
AKA: Greg King
b_mallerd's admonition is on target. It is why I mentioned not worrying about calculating drag because of all the other sources of variation. It is quite profitable to do the basic computations first, however. You want to find the boundary conditions for values such as release angle and motor speed so you know where to start your testing.
You should find things like the minimum angle required to even get the ball up to the center goal. If you are using a spinning wheel launcher you should figure out the minimum number of revolutions per minute to get the velocity you want. Computing these can also make your life much easier when it comes to testing because you will be able to be much more systematic.
Team 125 Ball Shooter Prototype! Brandon Holley Technical Discussion 21 21-01-2006 00:07
Ball Recirculation Question Nuts4FIRST Rules/Strategy 23 15-01-2006 15:35
Experimental Ball Drive Sepsis900 Technical Discussion 16 31-10-2005 16:59
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
