Go to Post Chief Delphi down for a few hours ON A WEEKEND??? This is MADNESS! - [more]
Unread 14-01-2006, 14:37
Reyner's Avatar
Reyner Reyner is offline
HEIGHT VIOLATION! BLUE TEAM!
FRC #1466 (Webb Robotics)
Team Role: Communications
Reyner will become famous soon enough
Send a message via AIM to Reyner Send a message via Yahoo to Reyner
Question New CIMs in kit transmission
Can we use the new (bigger) CIM motors in the kit-supplied transmission in place of the old (small) ones?
S1x240JrTBmsqf95DL06FdsTM33H!
The background music to the AIM HIGH animation has a fast moving gritty delta blues with a southern good ole boy feel.
I'd say that I don't like it as much as the music from 2005 but that's to negative
Unread 14-01-2006, 17:04
Swan217's Avatar
Swan217 Swan217 is offline
RoboShow Producer
AKA: DJ Royal Fusion
no team (RoboShow)
Swan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond repute
Send a message via AIM to Swan217
Re: New CIMs in kit transmission
Please search before you post. The answer is "NO"
www.Andymark.biz sells conversion kits for the transmissions to work with the bigger motors (as seen here).
The transmission designer Paul Copioli suggests, however, that you buy two more CIM motors and use 4 small ones. (As he says here)
Orlando Regional Planning Committee & Cohost of The RoboShow & RoboVision
Follow The RoboShow on Twitter @RoboShowLive & check out our website, www.theroboshow.net
Follow RoboVision on Twitter @RoboVisionOD & check out our website, www.robovisionod.com
"As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything."
— President Barack Obama
Unread 15-01-2006, 00:09
Reyner's Avatar
Sorry (I'm kind of new here), and thanks for the info. For future reference, what would I search for to find that?
Unread 15-01-2006, 00:23
Searching for "large CIMs" would probably do it, or maybe "kit transmission". There is a searching tutorial (referenced in the welcome announcement earlier in the month) with good ideas as to how specific you could get and your options.
Unread 15-01-2006, 03:41
atomikitten's Avatar
atomikitten atomikitten is offline
blowing things up, making things go
AKA: Megan
FRC #0888 (Robotiators (Glenelg Gladiators))
atomikitten will become famous soon enough
Send a message via AIM to atomikitten
they say don't use the new big mini-bike large CIMs for the provided kit transmission for a number of reasons. The RPM and torque are different, they draw different amounts of current, the size of the output shaft is different...
Yes, you can compensate for all of these things, but why would you? There's a conversion kit made my AndyMark. Trying to use the mini-bike CIMs with the kit transmission is a bad idea; it's not designed to work that way. If you want to use the mini-bike CIMs, it's better to use their conversion kit because a professional has already done the work for you.
Unread 15-01-2006, 15:51
Reyner's Avatar
OK, but the best thing I could come up with was this, which doesn't really answer my question.
Unread 15-01-2006, 16:59
B. Flaherty B. Flaherty is offline
AKA: Bill
FRC #1626 (Falcon Robotics)
B. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to behold
Send a message via AIM to B. Flaherty
I'm not sure if this will answer your question, but here is a link to the discussion about the picture of the Transmission Conversion.
http://www.chiefdelphi.com/forums/sh...threadid=41603
Hope this was of some help to you.
Boston Regional 2007 - Finalists (1626, 121, 1568)
Palmetto Regional 2007 - Finalists (1251, 1626, 1758)
Finger Lakes Regional 2009 - Semi-Finalists (1241, 229, 1626)
pic: Kit Transmission Upgrade kit Andy Baker Extra Discussion 17 29-01-2006 01:27
Kit Transmission KillerCows456 Motors 17 28-01-2006 17:10
Tapping Into Kit Transmission Casing Madison Technical Discussion 6 13-12-2005 14:29
Kit of Parts - Sprocket Spacers? and Transmission Lubrication? wmurphy Kit & Additional Hardware 10 13-01-2005 01:09
