Go to Post I still say animation is the illegitimate child of the FIRST family locked away in the attic and never spoken about. - Koko Ed [more]
Unread 15-01-2006, 00:30
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Fully autonomous robots?
I was thinking about how, this year, FIRST has shifted autonomous into user controlled mode. I foresee that many robots will be a hybrid of both technologies. User-controlled driving and autonomous-controlled shooting. Now, what if you programmed in an object avoidance system? What if you programmed your robot to try to evade all large objects (robots) coming at it and pick up all small objects (balls)? This pretty much eliminates all the necessity for a driver during offense.
So, the focus of this thread is:
Do you think an offensively autonomous robot is feasible?
If so, do you think it would be competitive?
If not feasible, why not? What specific function could a robot do that a human could not?
http://www.mikesorrenti.com/
Unread 15-01-2006, 00:37
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Fully autonomous robots?
Personally, I think that with the sensors we have available, a fully autonomous robot would be less competitive than a human driven one. I think it's just a lot easier for a human to say, "Hey, there's a ball, let me go pick it up," than for a robot to decide that that shape over there is a spherical game object and figure out how to change it's motors to get there (without pinning itself in a corner).
Primarily, I think the number one disadvantage comes from defensive driving. If I don't want you to get the to goal, I can play smarter than your algorithms. I can block your path, I can push you around, I can fool you into thinking you're on the other end of the field ().
However, I wish you the best of luck. It would be an amazing accomplishment.
Unread 15-01-2006, 00:40
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
The reason that it won't work is that there's sort of a hierarchy of what gets done:
1)Mechanical
2)Basic Driving Code
3)Basic autonomous mode
4)Telemetry
5)Advanced autonomous code.
Most teams only get to stage 2 or 3. In six weeks, there's just not enough time to make such a system work more reliably than a human driver.
Unread 15-01-2006, 02:16
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Having spent years working on similar software projects, that's true. However, to get around it, you start working on your software in April.
Unread 15-01-2006, 03:28
AKA: Eric
Very true. In at least the past couple years, you've been able to have all sorts of sensors and such that could be connected to separate processors, so you could work on designing a custom "black box" in the off season. Include a few gyros, accelerometers, encoders even some ultrasonic proximity sensors, and it could give you a very good idea of where you were on the field.
Then, in the season, there's almost no work except physically rebuilding it. You could have it just send back the position and rotation of the robot to the robot controller.
Unread 15-01-2006, 13:48
AKA: Tim Craig
I was thinking even more of reusable software for the robot controller. With the controller now C programmable, the software is very portable even if the processor in the controller changes. A number of "problems" in robot control appear in all robots, for instance, providing the transfer function from joysticks to drive motor outputs. How many robots have you seen slamming around the field because the team used the default algorithm of joystick in equals PWM out? The output of the Victor speed controllers is VERY nonlinear relative to the PWM number input. You can come up with a general solution that's data driven and then you only have to tweak the data to fit the next robot. The software is already written and debugged. From developing the software in the first time around, you probably even have an idea how to tweat the data to make it do what you want in the new robot.
Unread 15-01-2006, 01:52
sburro's Avatar
sburro sburro is offline
AKA: Joe
FRC #0663 (crusaders)
sburro will become famous soon enoughsburro will become famous soon enough
Send a message via AIM to sburro
I would also like to add that FIRST exist to get students interested in science and technology. A fully auto mode I think would take some of the fun away from this.
K.I.S.S
Keeping It Simple Stupid
Unread 15-01-2006, 01:56
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
It would be very difficult for an autonomous robot to adjust it's strategy mid-match to account for varying field conditions and scoring status. This is something a driver can do quite easily.
Unread 15-01-2006, 12:46
Mike's Avatar
AKA: Mike Sorrenti
Well, this varies from robot to robot. If your robot is one that can do everything (defend, pick up balls to throw into corner goals, shoot balls, etc.) then yes, this system may not be for you. However, if your robot only does one thing (shooting balls) all it has to do is pick up balls and shoot. I don't know what you mean by "varying field conditions." If there is a broken down robot in the way, it would treat it the same way as anything else and avoid it.
Unread 15-01-2006, 12:44
Mike's Avatar
AKA: Mike Sorrenti
On the contrary, I think a lot of people on other teams would be like "Woah! I wish our robot could do that!", thus inspiring them to create systems similar to this on their own.
Unread 15-01-2006, 15:04
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Theoretically, but not with our controller/libraries.
  • Such an advanced object detection/avoidance is a current area of R&D (ie, DARPA's Grand Challenge)
  • I'm not sure you could do that much processing within the constraints of IFI's library (processing must be done in 26.2ms chunks, the amount of IO)
  • $$$, and the rules about it
I do foresee, though, more automation this year. Especially with "Montana", I expect many robots will attempt at autonomous aiming. (I doubt many humans trying to aim a launcher will have very good accuracy.)
Unread 15-01-2006, 15:18
Mike's Avatar
AKA: Mike Sorrenti
Who says our controller has to be used? I think an offboard controller, communicating with the IFI controller at a decent speed would be sufficient.
- It would not have to be nearly as complex as The Grand Challenge. They were traveling 130 miles through a desert at speeds of 35mph. All our robot would have to do is stay on the offensive side of the field, and avoid ramming into walls.
- Offboard controller.
- A decent proximity sensor, with a couple foot range, would cost you about $25. For added accuracy, you can have a small array of these.
Unread 15-01-2006, 15:29
Is it impressive? Very.
Will I do it? No.
Will I support you in your quest to get this done? Yes.
Good luck on this Mike. We need more young minds like yours in this program to keep pushing the envelope of whats possible and whats not. (Who would have thought holomonic drive systems and 4 speed transmissions would be common items 6 years ago?!)
Unread 15-01-2006, 15:56
Andrew Blair's Avatar
FRC #0306 (CRT)
A completely autonomous game will never take off. Rookies would be lost. Veterans would be lost. But a combo can be done. Heres what the incentive needs to be:
1. Double points for every score autonomously.
Thats it. However, the robot would have to be entirely autonomous th entire match, or impose a rule that it must navigate from a specific area and score autonomously to get double points. That way, a team can't line up, hit a button, and call it autonomous. The way to ensure the team is doing it autonomously is to have a button that enables a separate automode. You can turn it off anywhere and regain human control, but you can't turn it back on until the robot is back in that specific area.
-Sir Francis Bacon
-Albert Einstein
Unread 15-01-2006, 16:14
nehalita's Avatar
nehalita nehalita is offline
Robots are friends
AKA: tagger fanatic
FRC #1345 (Platinum Dragons); FRC# 97 (RoboRuminants)
nehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond repute
Send a message via AIM to nehalita Send a message via MSN to nehalita Send a message via Yahoo to nehalita
(oh dear this is a long one. bear with me, i actually supported my statements so that's why it's long...)
Our team was actually talking about a possible hybrid of autonomous code and the use of drivers.
Ideally, a combination of both would make the robot more competitive. With the target far away, shooting at an angle could be more difficult than anticipated (this may not be true...obviously, we don't have a working robot that can shoot in the goal and drive around yet so this has yet to be determined). If we can use some autonomous code that automatically tracks the goal and provides the proper angle of inclination or speed, some human error can be eliminated.
However, I started off with "ideally" for a reason. The code has to be able to be properly developed, used, and corrected in time.
I personally feel that a fully autonomous robot would not be nearly as competitive. An autonomous robot doesn't have the awareness of its surroundings that we do looking across the field. What I like so much about this year's game is the amount of strategy needed. You cannot teach a robot strategy....at least not in the amount of time we are allotted.
I'm not saying that an autonomous robot isn't functionable but to be competitive, I still think we need a human touch -- that means the ease of going between offensive and defensive strategies and ensuring that no one gets in each other's way. Now, we still have that problem when we are controlling the robot (getting in each other's way) but we can easily fix that. To conjure a code that would anticipate all elements, possibilities, and problems into account would simply be illogical and impractical when, given our complex decision-making faculties, humans can do the same thing with a lot less effort.
Finally, I would like to point out that there are 3 of us on the field while there is one camera on the robot. We can decide what to do when a robot rams into us and figure out where to go next, the robot cannot. We can determine whether the corner goal is free alot faster than the robot can and if a robot needs help up the ramp, we can do that while an autonomous robot cannot see whether a robot needs help or not (or decide which robot to help in the even that both robots cannot go up the ramp). it cannot assess which robot would be easier to aid and even if we could devise a code to do that, it would be easier for a human to simply take 1/2 second to figure that out than spend several hours coding it into a robot.
So essentially, autonomous code can take out the guesswork but we still need humans to decide what's best to do next. If this games was 1 vs. 1, things would be different but we have 6 robots. Versatility is essential.
"Relativity applies to physics, not ethics." Thank you Einstein
MIT '10
Proud Member of H.I.L.
The PLATINUM DRAGONS are on FIRE!
A Warning to Human Players During Autonomous The Lucas General Forum 21 07-04-2005 02:29
Driving Robots under/into the Goals ... allowed? erniep Rules/Strategy 8 11-01-2005 22:32
Autonomous Program Names Venkatesh Programming 12 17-02-2004 10:25
autonomous..... Arefin Bari Rumor Mill 30 19-12-2003 10:53
crazy idea for autonomous Mike Ciance Programming 16 24-04-2003 21:50
