Go to Post Our opponents didn't know where our robot was going and neither did we! - ReapersRule [more]
Unread 14-01-2006, 20:41
gondorf's Avatar
gondorf gondorf is offline
inventor/solidworks engineering spe
AKA: stephen truscott
FRC #1733 (The Polar Bots)
gondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to behold
can the game flag be used?
the game flag can be mounted on top of the 60" robot. can we use this flag to defend against balls in the center goal? i mean the flag can extend up to the hoop so can we block the hoop with the flag?
also is there a limit on where we can put the flag?
Unread 14-01-2006, 20:47
Billfred's Avatar
Billfred Billfred is offline
Re: can the game flag be used?
From the manual (darn good reading):
<R13> Robots must use one of the two colored bicycle flags provided at the event queuing location to display
their alliance color (red or blue). Each robot must include a 12 inch long, 1/2” ID PVC tube, capped at the
bottom, permanently mounted on the robot such that when a 3 foot long, 1/4 inch diameter flagpole is inserted
the top of the flagpole is no higher than 6 feet from the ground and the top of the flagpole is at least 12 inches
higher than any other point on the robot (+/- 1/2 inch). The flagpole must be mounted such that it starts the
match, and remains, approximately vertical. The flagpole receptacle must be statically mounted, and not
articulated or actuated.
Unread 14-01-2006, 21:39
Nimmy Nimmy is offline
also Head of Strategy\Translation
AKA: Nimrod Amir
FRC #1577 (SteamPunk)
Team Role: Animator
Nimmy is a jewel in the roughNimmy is a jewel in the roughNimmy is a jewel in the roughNimmy is a jewel in the rough
Send a message via ICQ to Nimmy Send a message via AIM to Nimmy Send a message via MSN to Nimmy
the robot limit is 60" and the flagpole top must be 72"?
Unread 14-01-2006, 21:47
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Its right there in the rule that Billfred posted. If you have a robot that is in-fact 60" tall then yes, the top of your flag must be 72" from the ground. If your robot is not 60" tall then your flag may be at any height as long as it is under 72" from the ground and over 12" (+/- 1/2")from the highest point on your robot.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 15-01-2006, 00:41
No. You can't use anything over 5 ft. to block. Doing so is a 5pt penalty per occurrence or shot blocked, whicheveer is greater.
Unread 15-01-2006, 00:47
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Can you cite a rule on that please?
Unread 15-01-2006, 00:52
Originally Posted by Game Manual, Section 4.3.4.3
<G16>
Maximum Height - A ROBOT may not extend above 60” above the floor or the ALLIANCE PLATFORM in a stable configuration at any time during a match. Each violation shall result in a penalty of 5 points per occurrence or 5 points per ball shot or ball blocked during the occurrence, whichever is greater. ROBOTs designed to violate this rule are not allowed. For example, a ROBOT that extends a blocking device in front of the center goal will be disqualified....The one exception to the height restriction is provided in rule <R13> (flag rule).
At least, that's how my team interprets it. And of course, better safe than sorry, seeing as if the refs decide the flag is extenden in front of the center goal it's a DQ.
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
<G16> Maximum Height - A ROBOT may not extend above 60” above the floor or the ALLIANCE
greater.The one
So, my interpretation of this is that you will not receive a penalty for being over 60" so long as it's just the flag, however, if the flag blocks a shot, it's questionable as to whether or not you'd be penalized.
At any rate, the flag is what, a 1/4" stick or something? 3/8"? That's not exactly a large target. You'd have to have incredible precision to line the flag up properly to perfectly intercept the trajectory of an opponent's ball.
2001-2004: Team 100
2006-Present: Team 254
Unread 15-01-2006, 00:59
1/4" OD PVC with a bycycle flag on top. (<R13> has the details on mounting tube, placement, and all the other annoying little details.)
Unread 15-01-2006, 02:37
Rombus's Avatar
Rombus Rombus is offline
AKA: Rick Kosbab
FRC #4188 (Columbus Space Program)
Rombus is a jewel in the roughRombus is a jewel in the roughRombus is a jewel in the rough
Send a message via AIM to Rombus
A quick question on R13:
the last line reads:
Is this to mean that the flag must be mounted on the base of the robot? Or can we mount it to our ball turret that is going to rotate around as long as the receptacle itself is staticly mounted?
Unread 15-01-2006, 04:22
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
I would think that this would not be allowed, which is unfortunate because that makes it much more difficult to have a 360 degree rotating turret. You'd have to make it pivot around the flag pole.
Unread 15-01-2006, 14:01
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
A rotating turret will most likely not extend to the corners of the legal size of the robot because most people will have it on a circular rotating base. So you could put the flag in the corner of the robot. This would cause your launcher to have a small range in which it could not be used due to the flag being in the way.
See you in DC!
Unread 15-01-2006, 14:26
psycho7 psycho7 is offline
pyscho
AKA: (ex-freshman)
FRC #1831 (Screaming Eagles)
Team Role: Scout
psycho7 is on a distinguished road
Send a message via AIM to psycho7
Post Re: can the game flag be used?
With the flag being as small as it is. The chances of blocking or even interfering with a shot on the high goal is minimal, so if it does happen it will most likely be by accident, so hopefully the refs will not penalize. This is at least my interpretation.
Unread 15-01-2006, 15:49
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
I'm curious about that. Let's say this:
Robot A is on offense, it lines up with the goal and pops off a ball at 12m/s or so at the goal, in the middle of its perfect arc a defensive robot drives by, with no intent to block at all, but the ball hits the flag, do they get a penalty? What if there's obvious intent to block? What if it's a robot from their alliance?
Could be interesting...
Matt Krass
Unread 15-01-2006, 15:54
pakrat pakrat is offline
Rich Ross
no team (The Rat Pack)
pakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nice
Send a message via AIM to pakrat
I really dont think that a ball blocked by a flag will be called for a penalty. If it happens more than once or twice, maybe they'll make a rule about it, but I think that it won't really happen much.
[Official 2006 Game Design] OK, so YOU design the 2006 game... dlavery FRC Game Design 29 08-01-2006 00:21
[Official 2006 Game Design] Autonomy And Other Technology Discussions dlavery FRC Game Design 36 12-11-2005 17:49
2004 Season for Fantasy Football, FIRST Robotics league Alex Cormier Chit-Chat 155 29-12-2004 13:12
i didnt like this years game....please read archiver 2001 19 24-06-2002 03:23
Fresh from the forum Ken Leung CD Forum Support 3 15-01-2002 22:22
