Go to Post It's far easier to find ambiguity in the rules than to write them. - MikeE [more]
Unread 14-01-2006, 22:47
Re: pic: 1251 Prototype v 1.2
Originally Posted by Andrew Blair
The size of the wheel has nothing to do with the RPM of them (Unless you say that their mass slows down the system). If we know the output speed of the Kit gearbox, and we know the ratio to the the wheels, we can, with some error, find the RPM of the wheels. Now, if we were looking for the linear speed from a reference point on the wheel, then wheel size would matter.
Who says the trannies are running at full power?
Unread 14-01-2006, 23:17
i_am_Doug i_am_Doug is offline
Currently foraging for food..
AKA: Doug
i_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura about
Send a message via AIM to i_am_Doug Send a message via MSN to i_am_Doug Send a message via Yahoo to i_am_Doug
EDIT: im now guessing your team number ;p 1251.
Unread 14-01-2006, 23:25
Stephen P's Avatar
Stephen P Stephen P is offline
Stephen P has a spectacular aura aboutStephen P has a spectacular aura about
Originally Posted by tkwetzel
Well...I finally made it back to Chief Delphi after being away for so long.
The sprocket size should not matter at all to answer their question. They asked how fast the wheels were spinning, not the motors. With an angle and distance you need the size of the wheels and possibly height of the arc of travel to find the rpm of the wheels to launch one of the foam balls that far.
Without calculations I will guess that the wheels are spinning at 1,900 rpm.
You couldnt find out the rotational speed from just projectile distance, becausethis would require the assumption that 100% of the wheels energy is translated into the ball (a horrible assumption).
You know you are an electrical engineer when you can determine voltage relative to pain with a 5% error.
Unread 15-01-2006, 01:42
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
That is not true. You could assume whatever efficiency of energy translation you want, but whatever number you use would be an estimate without knowing other information. You also have to estimate a few otehr numbers. But tehy gave you the angle and distance traveled.
See you in DC!
Unread 15-01-2006, 12:17
Andrew Blair's Avatar
FRC #0306 (CRT)
Thats one of the easiest assumptions. They're running the motors straight off of the battery, so the speed of the output is defined only by the battery voltage. Its rather easy to say that they were running a fairly charged battery; most people don't run a battery to nothing and then use it to power a launcher. An easier assumption than the estimation of the size of those two sprockets.
-Sir Francis Bacon
-Albert Einstein
Unread 15-01-2006, 12:19
FRC #0306 (CRT)
You could, but the easiest assumption to use is the motor/tranny speed to the wheels. Problem with using the ball's throw is that you must estimate he distance, then the power transmission efficiency, then backsolve for RPM. Lots of error, though either way. it's hard to guess.
-Sir Francis Bacon
-Albert Einstein
Unread 15-01-2006, 15:06
SpaceBoy2000's Avatar
SpaceBoy2000 SpaceBoy2000 is offline
Guy with Hammer in CAD cabinet
AKA: Michael Kwan or Frogger
FRC #0610 (Coyotes)
SpaceBoy2000 is on a distinguished road
Based on my team's prototype, 2885 RPM
EDIT: I'm assumming 8' wheels too there...
EDIT 2: Whoops, forgot to add in sprockets
Unread 15-01-2006, 15:52
pakrat pakrat is offline
Rich Ross
no team (The Rat Pack)
pakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nice
Send a message via AIM to pakrat
Well, I dont have a guess, But i will say that thing looks pretty sweet. Have you guys looked at the difference between running 2 spinwheels on each side as opposed to one?
Unread 15-01-2006, 19:20
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
A couple of more hints.
-The wheels are 8 inches
-We assumed that only 75% of the distance covered by the spinning wheel gets to the ball. We were looking for the speed limit.
It's too easy now.
Dave
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 15-01-2006, 20:19
nehalita's Avatar
nehalita nehalita is offline
Robots are friends
AKA: tagger fanatic
FRC #1345 (Platinum Dragons); FRC# 97 (RoboRuminants)
nehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond repute
Send a message via AIM to nehalita Send a message via MSN to nehalita Send a message via Yahoo to nehalita
2560 rpm?
Wait... does 37 feet mean 37 feet horizontally?
Unread 15-01-2006, 20:23
Smithvillefirst Smithvillefirst is offline
Anthony Peck
FRC #1806 (Smithville First)
Smithvillefirst is an unknown quantity at this point
Thumbs up Re: pic: 1251 Prototype v 1.2
From the video sound it sounds as if you need to grease the gearbox ours was the same until it was well greased.
Anthony Peck,
Integration Manager
Team 1806
Unread 15-01-2006, 21:36
AKA: Dave
The gear boxes are greased but haven't been checked since last year. Most of the noise is coming from the chain.
Yes, 37 ft horizontally.
Unread 16-01-2006, 11:10
cire's Avatar
cire cire is offline
Alumni, Mentor, and Coach
AKA: Eric Diehr
FRC #1716 (Redbird Robotics)
cire is just really nicecire is just really nicecire is just really nicecire is just really nice
Send a message via MSN to cire
Looks like 1269 RPM to me
gear ratio * free speed of kit transmisson
3:1 * 423 rpm = 1269 rpm
edit - I estimated that the larger sprocket was 36T and the smaller one was 12T by looking at the picture.
Unread 16-01-2006, 12:14
I know I'm coming late to the party, but 1,250 rpm, plus or minus two weeks.
(Bonus if you recognized the obscure movie reference.)
pic: TechTigers shooting prototype David Guzman Extra Discussion 11 12-01-2006 07:23
Programming a 2nd PIC ImmortalAres Programming 8 16-06-2005 12:13
Segway Prototype Components For Sale MattK Chit-Chat 5 15-02-2005 16:34
pic: Swerve^2 Prototype CD47-Bot Robot Showcase 24 23-01-2004 12:11
pic: Team 857 Prototype Killough 2002 CD47-Bot Extra Discussion 19 13-10-2003 08:12
