Go to Post The rules also never explicitly say that I can't park a Boeing 747 right in the middle of the play field and use it as an obstacle for the other alliance. But after a little thought, something tells me that I probably should not do it. - dlavery [more]
Unread 15-01-2006, 14:26
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Creating new MPLab Project
Originally Posted by Mike
Ok, so I did that. I also had to have a custom error suppressantt added to my build options, so I now use the "User alternate settings" function. So to add a macro, I found out that I needed to append -D_MACRO_NAME to my build options. My total build options are now
-D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
But now I get the error
Any idea of what's wrong now?
I believe this is akin to the infamous syntax error. It decided it didn't like you, or something.
First try cleaning the project and rebuilding (in case of file corruption). Then try changing some compilation options. (eg, optimization)
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
openFIRST Project Announces Pending Deadline for End of Support for Old Versions Timothy D. Ginn FIRST-related Organizations 0 11-07-2005 22:40
Printing of a project in MPLAB DanDon Programming 0 10-01-2005 21:10
