Go to Post "So we have an arm, and the pot on it tells how high we are... ...and then we know how high we want to be... ...and if we're not high enough we go higher." (I have to leave the room, we're all laughing too much.) - demosthenes2k8 [more]
Unread 15-01-2006, 14:51
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Mixing Joystick Values for mecanum wheels
Originally Posted by SoftwareBug2.0
There are other ways of doing this that will get you the full range of values. By the way, the range is 0-255.
Technical note, 255 may be ok, but is also used in the packet header. If you have strange problems with victors not responding or PWMs not changing, try changing that maximum to 254. (I don't remember off-hand any instances where this was the case.)
Getting A Bot To Turn Andrew Blair Technical Discussion 20 16-10-2005 23:49
Change joystick to pwm mapping Joe Lewis Programming 3 30-03-2005 19:27
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
