Go to Post Seriously I didn't think that "FIRST, it's the WWF for smart people" would ever catch on. - Schnabel [more]
Unread 15-01-2006, 13:46
Fred Agnir Fred Agnir is offline
Hit and Run Lurker
#0126 (Gael Force)
Fred Agnir has a spectacular aura aboutFred Agnir has a spectacular aura aboutFred Agnir has a spectacular aura about
Switching Channels
I can't seem to switch the channel out of the default Ch. 40. I'm using my jumpers from the previous years (we have several), and none of them switch the channels. We have no problem switching channels from last year's controls.
Has there been a change that I'm unaware of?
Fred
Fred Agnir
Automation and Robotics Engineer
Nypro Inc. / Clinton High School
Controls Lead
~Never Stop Learning. I haven't~
Unread 15-01-2006, 15:22
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: Switching Channels
You have to set the most significant bit of the team number to 1. (Team number > 2048)
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 16-01-2006, 20:46
tckma's Avatar
tckma tckma is offline
AKA: Tom C.
FRC #2199 (Robo-Lions)
tckma has a spectacular aura abouttckma has a spectacular aura abouttckma has a spectacular aura about
Send a message via ICQ to tckma Send a message via AIM to tckma Send a message via Yahoo to tckma
I don't remember having to do that last year, is that new? We had rigged up a prior year's robot as Team "1101" just to have a different team number... sometimes we swapped the MSB instead of the LSB. But I don't recall it *needing* to be the MSB. (and think about it, this is the same way they do it with different channels in the actual competitions.)
Tom C.
Software and Controls Mentor
Team 2849
Prior team associations: 1418 ('08-'09), 1100 ('05-'08), 811 ('02, '04-'05), 246 ('03)
Unread 16-01-2006, 20:54
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
I believe it was new last year.. I think it was as a replacement for using the channel jumper, but I'm not sure.
In either case, the OI or RC reference manual will tell you exactly how.
Unread 16-01-2006, 21:14
Bharat Nain's Avatar
If you are using pre-2005 controllers, then you need a dongle with a program mode in it to change channels. Otherwise I can point you to an excellent white paper written by Josh Hambright. This should clear all questions.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 20-01-2006, 20:54
Hit and Run Lurker
#0126 (Gael Force)
That should do it.
Thanks,
Fred
Fred Agnir
Controls Lead
Encoder Code Kevin Watson Programming 47 18-02-2008 12:56
Selecting alternate radio channels on 2005? Alan Anderson Control System 2 20-01-2005 10:15
Split topic - How many channels can the current (2004) Oi's and Rc's Handle? Elgin Clock Control System 6 02-01-2005 14:02
Team 45 Dual Motor Gear Switching Assembly WorkThoseBuns Motors 1 20-03-2002 19:27
[white paper] Dual Motor Gear Switching Assy Brandon Martus Motors 0 29-06-2001 12:56
