Go to Post FIRST MANTRA: When Lawyer-ism fails, Gracious Professionalism Prevails! - sanddrag [more]
Go Back   Chief Delphi > Other > Car Nack's Corner
Unread 15-01-2006, 11:05
Car Nack Car Nack is offline
Car Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond repute
Car Nack Reluctantly Predicts 2/06
The "real time" scoring system will have problems and at times FIRST will have to use at least four "real time humans" to allow the competition to continue. Car Nack sincerely hopes he is wrong with this prediction.
May your oasis be lush and green.
Car Nack has spoken
Unread 15-01-2006, 12:10
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: Car Nack Reluctantly Predicts 2/06
Car Nack has spoken
Machines aren't perfect and I truly hope FIRST has a backup system that will minimize controversy.
Unread 15-01-2006, 12:16
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
If there's a problem it probably would be on the software side. At kickoff Woodie said they tested those camera counters pretty thoroughly.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 15-01-2006, 12:17
Jessica Boucher Jessica Boucher is offline
FIRST Historian
Jessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond repute
Great thought. This would probably be good to factor into the volunteer numbers at each regional just in case, especially in the earlier weekends. I may not want it to happen, but it's better to plan ahead so that the competition can keep running smooth.
jessicaboucher.com
FRC Alum, Mentor, Volunteer, lots of things.
Championship Volunteer of the Year, 2016
Advisor, NE FIRST
Unread 15-01-2006, 12:21
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
If there are many machines like pumping balls in the hoop like this Video from Rage, I am very concerned about the ability of the scoring system!!!
Joe J.
Team #88, TJ2
Unread 15-01-2006, 12:25
Andrew Blair's Avatar
FRC #0306 (CRT)
Joe J.
Yeah, but we'll see. Where are they going to get an oompa-loompa to feed the thing?
-Sir Francis Bacon
-Albert Einstein
Unread 15-01-2006, 13:12
Billfred's Avatar
Billfred Billfred is online now
I dunno, but they have 37 days to do so.
IANAE, but it seems like a backup system could be implemented with a bit of work (and an order from Newegg for a few dozen webcams). Record the goals during the matches, play it back to get a count. Assuming you would have to record for five more seconds to be sure all the balls were counted at the end, you'd have 360 goal-seconds of video to review. Break that up across a team of five or six official scorekeepers, and you should be able to determine the scores in about as much time as it historically takes for a FIRST match to be scored.
Hopefully, though, we won't have this problem. (Perhaps we should establish a cookies bounty for a problem-free season? I mean, you throw cookies into the mix and it's on! )
Unread 15-01-2006, 13:22
Bharat Nain's Avatar
This thing has been worrying some of our team for a while too. I hope FIRST figures it out though because the game is not that hard to ref other than counting balls.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 15-01-2006, 15:29
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
My team is participating in a first week regional so I'm assuming that there will be problems. Hopefully by nationals they will have sorted it out or at least have a well defined system for how the reffing of it will work out.
Team Website
Unread 15-01-2006, 15:33
Joe J.
I would be more concerned with the One Point goals. They are a few feet wide, and the only sensor is a camera on top that picks up breaks in a band of light on the floor. (The center goal uses a sensor in the tube that feeds the human player, and only one ball can pass it at a time.)
Woodie said they bought 30-something new dual core computers, which will be dedicated to running the real time scoring at events. Yes, any algorithm to track the path of many balls passing through the light beam at a time would be tough, but I wouldn't put it past some of the minds FIRST has working with them.
Unread 15-01-2006, 16:37
Chase's Avatar
Chase Chase is offline
Construction/Photographer
AKA: Chase
FRC #1546 (CHAOS INC.)
Team Role: Student
Chase will become famous soon enough
Send a message via AIM to Chase
I'm not too worried, I don't think they'd agree on a scoring system unless they were perfectly confident it would work.
CHAOS INC. Team #1546
2005-Long Island Regional-Rookie Allstar Award
2006-Long Island Regional-Sportsmanship Award
I was going to list all the funny quotes I've collected from our team over the past few years, but I have way too many.
"I don't care how you do it, we need to raise money. Jump a freshman..." -Ms. Reiss
Attending: Deer Park Invitational, Brunswick Eruption 2006, SBPLI Long Island regional, Championship Event?
Ban Comic Sans
Unread 15-01-2006, 16:38
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Quite right. With all this talk of shooting 10+ balls/sec into the center goal, not having seen the real setup up close, I wonder if it's possible to saturate and jam the goal full of balls so that they can't properly fall one by one down the scoring tube?
If this is possible, I wonder if a FIRST volunteer or ref is supposed to jar the balls loose when jammed or just leave them alone.
Unread 15-01-2006, 17:00
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
Originally Posted by T. Hoffman
Quite right. With all this talk of shooting 10+ balls/sec into the center goal, I wonder if it's possible to saturate and jam the goal full of balls so that they can't properly fall one by one down the scoring tube.
I believe that the chain and the sloped ramp in the center goal will prevent 99.90% of jamming. I think that FIRST worked hard to develop a system that would not break so easily, If anything FIRST probably overestimated first teams abilities
lets work hard to prove them wrong
http://www.wcsrobotics.com
team 663
team 1493
Unread 15-01-2006, 18:26
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
Actually if anyone watches the kickoff video, in the very beginning while releasing the game to the world, while the GDC was shooting the balls they were indeed getting stuck on the ramp, and we have tested the possibility on our goal and it can happen.... should be interesting to see what finally ends up happening though.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 17-01-2006, 22:36
Validius's Avatar
Validius Validius is offline
There is a shadow following me.....
AKA: Mark Ratering
FRC #1549 (Washtenuts)
Validius will become famous soon enoughValidius will become famous soon enough
Send a message via AIM to Validius
I'm with car nack on this one.
When a sociaty comes to believe that human life is not inherently worth living, it is a slippery slope to the gas chamber. You wind up on a low road that twists past Columbine and leads toward Auschwitz.
-Peggy Noonan
Car Nack Predicts #4 Car Nack Car Nack's Corner 1 14-04-2005 10:57
Car Nack Predicts #4 Car Nack Car Nack's Corner 0 29-03-2004 11:18
Car Nack predicts #3 Car Nack Car Nack's Corner 2 03-03-2004 09:24
Car Nack Predicts Car Nack Car Nack's Corner 0 14-01-2004 10:57
Car Nack Predicts archiver 2000 2 23-06-2002 21:59
