Go to Post Remember everyone, during build season, if you mess something up..... In the words of Adam Savage... Failure is always an option! (and so is blowing stuff up) - J.Warsoff [more]
Unread 10-01-2006, 19:49
eiii eiii is offline
AKA: Erich Merrill
None #1823
eiii has a spectacular aura abouteiii has a spectacular aura about
Send a message via AIM to eiii
Re: Anyone thinking NERF ball turret
Originally Posted by KrtZer0
Turrets are very legal.
the big issue for our team is side-loading vs bottom-loading.
We are actually probably going to end up with the launching device being part of the turret with just as much movement allowed., Remember, the longer the ball stays enclosed without direct propulsion, the slower and less accurately it will go
the 'no open system' refers to the covering of fast/dangetously moving parts. There have been some pics up of teams launching through two fast-moving belts and for safety reasons, the final model will need to have those belts covered from the outside. The same will go for spinning gears and wheels that could possibly come in contact with another bot.
Thanks.
Why do I bother being witty if no one lives to see it?
Unread 10-01-2006, 21:36
Stephen.Yanczura's Avatar
Stephen.Yanczura Stephen.Yanczura is offline
opportunist
FRC #0195 (Cyberknights)
Stephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to all
What I ment about no open systems, was that you cannot design the air system just to dump to the atmosphere such as an air cannon design. Now that was my belief but upon scaning the rules I found nothing to back that up. So perhaps that is not the case. Would anyone like to offer input on that?
Unread 12-01-2006, 15:04
Taylor's Avatar
Taylor Taylor is online now
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
At the kickoff they spent an awful lot of time talking about the softball launcher - surely they wouldn't have been misleading us would they?
Are softball launchers compatible with a tube? Would it improve accuracy or put sidespin on the ball, forcing it to hook or slice?
And I know you're not Shirley.
Hi!
Unread 12-01-2006, 15:24
They wouldn't intentionally provide misleading information in the official presentation of the game. However, the game with the rocking ramp (Diabolical Dynamics?) was won using a scheme which ignored the example of a single robot balancing on the ramp while holding on to one goal at each side. The teams who followed that example lost the opportunity to have all four robots score bonus points at the end of the match.
So consider well your options. A spinning-wheel ball launcher is an obvious choice, but it might not be the winning one.
Unread 14-01-2006, 21:20
Leo 1529's Avatar
Leo 1529 Leo 1529 is offline
uber fabricata, webmasta, president
AKA: Tzu-san
FRC #1529 (Cyber-Cards)
Team Role: Webmaster
Leo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura about
yeah i thought that a spinning-wheel launcher would be a real common feature on most of the robots. I dont know if we are still considering even using a cannon or pitching machine on our robot
Unread 14-01-2006, 22:09
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Surprisingly the cannon extension will not provide as much accuracy as you may think. At least that is what we found from our prototyping.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 14-01-2006, 22:49
TEAM456MS TEAM456MS is offline
FRC #0456
TEAM456MS is an unknown quantity at this point
You could use a spring then pull back a plate inside the turret with a winch. It would be semi simple design that would follow regulations.
Unread 15-01-2006, 11:52
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
What i have figured out, there are only 4 plausible ways of firing a ball.
1. Single wheel shot (pitching machine on kickoff video)
2. Multiple wheel shot (more advanced pitching maching, look at a batting cage)
3. Catipult
4. Pneumatic piston/spring shot (both similar in a platform pushing the ball out)
Unread 15-01-2006, 12:21
Andrew Blair's Avatar
FRC #0306 (CRT)
Don't forget "Flywheel to linear transition" thrower"...
-Sir Francis Bacon
-Albert Einstein
Unread 15-01-2006, 16:05
FRC #0599 (RoboDox)
Can you show me an example. i can up with this basic list in like 2 min, so i want to know what the fly wheel to a linear transition is?
Unread 15-01-2006, 16:45
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
I'm not sure if this is what Blair was going for but this is what i'm envisioning. First place a ball on a cart like object that can carry the ball and make it travel on a short track. Then take a flywheel and bring it into contact with the cart to accelerate it. the cart should travel until it hits a stopper making it stop and any ball on it flying off. It seems like a nice compromise between a flywheel and some other sort cannon mechanism. You get consistency because you're always shooting the same cart object, but it isn't quite as fast and quickly repeatable as a straight flywheel. If you springload the cart so that it automatically comes back you wouldn't have to devote another motor the cart mechanism.
Team Website
Unread 15-01-2006, 16:51
FRC #0599 (RoboDox)
that still is categorized in the one wheel system, its just a small modification.
Unread 15-01-2006, 17:06
FRC #0306 (CRT)
Eh, something like like. Your's is better. There was a thread on here before about converting rotational into linear motion. That was what I referring to. But it seems rather feasible. The other option is to have a flywheel somehow coupled to a rod so that you can throw the rod forward. Rod hits ball, ball goes out.
-Sir Francis Bacon
-Albert Einstein
Unread 15-01-2006, 17:28
warcommander200's Avatar
warcommander200 warcommander200 is offline
FRC end-effecter group
AKA: David
FRC #0116 (Epsilon Delta)
Team Role: Student
warcommander200 will become famous soon enough
Send a message via MSN to warcommander200
that might be fine as long as you remember that the ball we are using for the game is made to absorbs force so it would require 2x the force to send the ball the same distance. plus a spring would constantly lose it rebound as the match went on.
Unread 15-01-2006, 21:34
occra 23.
AKA: ryo
None #1481
think crankshaft or camshafts too
also how about gravity fed trbuchet style or bow and string mangonels. crossbowish stuff.
so basically simply put the list gets to be
angular kinetic energy (flywheels and the such)
gravitational potential energy (obvious)
elastic potential energy (bows. cross bows. springs. bungees)
compressed gas
electrical(as in motors so i guess this is kinda angular kinetic)
mind power(technically unless you need to send radio waves from your head you dont even need to have the driver do this. someone in the stands can do this.. and even shoot down opponent's shots. but maybe violates GP? i unno
some sort of chemical reaction or sumthing. probably not legal
Experimental Ball Drive Sepsis900 Technical Discussion 16 31-10-2005 16:59
Ball Shooter Squall Rules/Strategy 7 11-01-2005 14:47
Lip at ball chute opening Doug Traster Rules/Strategy 1 19-01-2004 01:33
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
