Go to Post I can't wait till FIRST starts giving anti-gravity kits inside the kit of parts. - Rob Colatutto [more]
Unread 15-01-2006, 20:01
Melissa Crues Melissa Crues is offline
FRC #0974
Melissa Crues is an unknown quantity at this point
Tracking and Focusing
I have my camera up and running but it only locates the light if it is within 2 feet. Also, once it finds the light, it pans slightly to the left of it and can't track the light when I move it. Is this just a focusing problem?
Unread 16-01-2006, 01:16
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
Re: Tracking and Focusing
Have you tried to track with the pan and tilt servos hooked directly to the camera control board using the LabVIEW GUI? To do this, you need to hook the camera directly to the computer using the standard serial port connector, then open the CMU_Demo (you can find it here). You should try to grab a frame and check if the image is out of focus.
If this is not the issue, you may need to check you calibration values or reverse the pan servo. To reverse the servo refer to the CMU_Cam workbook (you place a jumper). If this works, it will have to be reversed in the code for the robot (as this controls the servos directly). Search around the forums for instructions on this switch and finding and applying calibration values. The camera workbook can also solve many issues.
FRC Volunteer, FLL regional planning committee member for Colorado
Former Programmer, Web Designer, Communications Director of Alpine Robotics Team 159.
Add your team to the FIRST Teams Google Map
