Go to Post By far, the worst thing about it was the severe lack of cowbell. There was no cowbell what so ever. Had there been cowbell that would have completely changed everything for me. - Wildcat [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 15-01-2006, 20:44
CmptrGk's Avatar
CmptrGk CmptrGk is offline
Programming Mentor
AKA: Dillon
FRC #0716 (Who'sCTEKS)
CmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud of
Re: Labview CMUcam demo problem
Originally Posted by Windward
Currently, I'm trying to get labview to work with the CMU camera. The camera is powered and our serial plug is plugged in, yet when I set the com to comport4 and press run, it does not run. I am not sure what the problem could be. I am not sure what the program demo itself is supposed to do, but I get an error stating there was a problem connecting. The error states that the error could be because of lack of power or a serial connection problem.
But I am pretty sure there is power and it is connected properly.
FYI, we are using a USB to serial converter, which works with the robot controller.
Any advice?
i had a similar problem, in device settings i changed the port that the converter "was" to com1 and it worked. at least for me the gui wont see anthing above com3
"Great autonomous mode Dillon."," It hasn't been written yet"
after an Archimedes match
National Instruments LabVIEW and Data Acquisition Forum Danny Diaz National Instruments LabVIEW and Data Acquisition 1 16-01-2006 13:20
LabVIEW - CMUcam finds target but cant track bear24rw Programming 6 13-01-2006 21:43
Problem installing Labview Joohoo LabView and Data Acquisition 3 08-01-2006 10:51
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
