Go to Post “Chasing perfection is like trying to find a unicorn. If you go all around the world, you will not find a unicorn. However, you will find a whole freak load of stuff along the way.” - Karthik - Jacob Bendicksen [more]
Unread 15-01-2006, 17:36
Xero0ne Xero0ne is offline
FRC #0358
Xero0ne is an unknown quantity at this point
Team 358 Shooter Prototype
Below is a link to our prototype ball shooter.
shooter prototype.wmv
this is a prototype using the minibike motor to drive 2 aluminum wheels coated with friction tape. The vast majority of the inconsistancy is due to the feed mechanism. There are, however some belt slippage issues, which were responsible for the rest of it.
Unread 15-01-2006, 17:47
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Re: Team 358 Shooter Prototype
looks cool!
I have some questions i hope you wont mind answering:
1)what is the gear reduction bwetween the motor and the wheels.
2)how did you connect the motor to frame?
3)how did you transfer the power? (belt/ chain)
4)if belt, as implied by post, where did you get the matching parts? (i.e. the belt and the other belt compatible sprocket)
5)are both wheels moving?
hope that's not too intrusive!
Thanks!
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 15-01-2006, 18:43
Kelvin Ng Kelvin Ng is offline
None #1558 (ACCIDENT Robotics (Albert Campbell Collegiate Institute stuD)
Kelvin Ng is on a distinguished road
Wow, good job! Seems like alot of teams are making accurate shooter mechanisms...this this should be an interesting year.
2005 - Waterloo Regional Highest Rookie Seed
2005 - Theory6 (1241) Top Rookie 2005
Unread 15-01-2006, 18:47
Andrew Blair's Avatar
FRC #0306 (CRT)
Very similar to ours, though we used a small instead of a large CIM. I'm glad to see that the RPM difference isn't an issue, as that is what we plan to use eventually. Great job guys!
-Sir Francis Bacon
-Albert Einstein
Unread 15-01-2006, 18:52
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
Nice job team 358. Look forward to seeing you at UTC New England in March.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 15-01-2006, 23:37
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
Originally Posted by Leav
looks cool!
Thanks!
-Leav
Thanks for the nice comments....
Leav - Your questions are not intrusive at all. As was said, this is a prototype, and we still have some work to do, but the following are the answers based upon what you see in the video:
1, 3, 5) There is a 2:1 gear ratio off the mini-bike motor, to timing belts which rotate (2) 4" drums.
2) The motor is connected to the frame by means of replacing the motor length assembly screw to match the other longer motor assembly screw. These screws then attach the motor to the gearbox.
4) These are standard gears and timing belts/pulleys, available from places like McMaster Carr, Small Parts, MSC, Stock Drive Products, etc...
I hope that helps.
Jon K. - It's our first time at UTC, and we look forward to seeing you guys/gals as well. By the way, very impressive teaser!!!!
Scott5736 (formerly Scott3137(formerly Scott358))
Unread 16-01-2006, 04:02
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
I'm starting to notice a lot of people using the minibike motors for their shooting mechanism. My team and I seem to think the smaller CIM motors will pay off when shooting balls repeatedly.
Unread 16-01-2006, 08:22
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Wow, I guess I'm missing out this year, maybe I'll stop in this week to see what else you guys have done without me.
- from B B frank
Unread 16-01-2006, 09:21
Engineer/Mentor
AKA: Scott5736
Hey Alekat,
What makes you think the smaller CIM's will be more repeatable?
Unread 16-01-2006, 13:09
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
It works pretty well and it's got a pretty good kick to it, hit me at 12 feet away and it hurt!
I'm also curious as to why the smaller CIM would be more repeatable?
Matt Krass
Unread 16-01-2006, 14:29
gondorf's Avatar
gondorf gondorf is offline
inventor/solidworks engineering spe
AKA: stephen truscott
FRC #1733 (The Polar Bots)
gondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to behold
this is a cool design
i guess that the design was sort of like the baseball shooter.
maybe ill show my team and they might start taking suggestions
Unread 16-01-2006, 17:00
in between teams
AKA: Luke Van Oort
Originally Posted by Scott358
Hey Alekat,
I think the meaning is that the small CIM's higher ultimate power will let you shoot more balls in a row. The repeatable might just be a typo.
Team 1219: 2009 - Mentor
Unread 16-01-2006, 21:44
Simon Strauss's Avatar
Simon Strauss Simon Strauss is offline
None #1155 (Sciborgs)
Simon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant future
Send a message via AIM to Simon Strauss
what were the exact specs for the belts you used and where did you get them? i spent most of my time in the shop today looking for timing belts online but i couldnt find anything that fit the 3mm pitch 15mm width that had been mentioned on the forums before.
NYC Chairmen's Award Winners 2007 Thank you team 2265, you were our project and we couldnt have done it without you all
New Jersey Regional Finalists thanks to teams 359 and 486 Aloha
"Beware of the Ska Robot Army!" -The Aquabats
Unread 16-01-2006, 22:35
Engineer/Mentor
AKA: Scott5736
Actually, we're changing what we used in the prototype, as we went for the smallest, lightest weight pulleys we could find, but they were not holding up.
They were MXL aluminum pulleys and 1/4" wide timing belts (where the "M" stands for mini).
We're moving up to XL steel pulleys and 3/8" timing belts for a more robust system. We'll know more about how this works tomorrow.
As far as were we are getting materials, I've found that StockDriveProducts.com has a very good selection, and most items available.
Hope this helps.
Unread 20-01-2006, 21:03
mdicicco's Avatar
mdicicco mdicicco is offline
JPL Roboticist
FRC #1160 (Titanium)
mdicicco is an unknown quantity at this point
Send a message via AIM to mdicicco
Check out Stock Drive Products: http://www.sdp-si.com/
"It won't break, unless I bend it like this." *SNAP*
-Me
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
Who do you think is the best bet to win the Chairman's Award at the Championship? Koko Ed Chairman's Award 58 29-04-2005 16:39
Free Kittens/Tetra Grabber Mr. Lim Rumor Mill 30 08-04-2005 11:36
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
**FIRST EMAIL**/Important Information for All Championship Teams! Jeremy Roberts FIRST E-Mail Blast Archive 0 09-04-2004 21:12
