Go to Post ..."A bad day at college is always better then a good day at work" - KyleGilbert45 [more]
Unread 15-01-2006, 23:59
B. Flaherty B. Flaherty is offline
AKA: Bill
FRC #1626 (Falcon Robotics)
B. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to behold
Send a message via AIM to B. Flaherty
Re: Drive train and gearboxes
Originally Posted by Cory
This is not true. They will run perfectly fine with only one CIM per side. You just lose the advantage of having extra torque and being able to share the load between motors.
Thanks for the clarification and correcting me. I knew that they would run on one CIM motor, just wasn't sure of the advantages/disadvatanges.
Boston Regional 2007 - Finalists (1626, 121, 1568)
Palmetto Regional 2007 - Finalists (1251, 1626, 1758)
Finger Lakes Regional 2009 - Semi-Finalists (1241, 229, 1626)
Direct Drive Four Motor System Collin Fultz Technical Discussion 42 02-11-2006 12:03
[ECDU]: Right drive train for this game Michael Leicht FIRST-related Organizations 4 03-04-2005 22:31
What type of drive train did you make this year? James114 Technical Discussion 31 12-03-2005 19:11
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
Another chapter in the drive train story AdamT Technical Discussion 19 29-09-2002 13:52
