Re: Example LabVIEW Apps - Dashboard, CMUcam2 and Motors
The power switch should be at the top. If it's not, then the camera is upside down. As for the reversed tracking, there are two jumpers on the camera for reversing the horizontal and vertical tracking directions. Try putting a junper on the vertical one. Good luck! -Joe |
Thanks Joe.
I see the problem... The assembly diagrams all show the board with the switch at the bottom, but the connection diagram shows it up the other way. I hadn't noticed those reversing jumpers. Thanks for the excellent tip. Phil. Quote:
I have a feeling the camera was put in the documentation upside down on purpose to keep you on your toes. Take everything you find with a grain of salt. Cheers! -Joe |
(.....mumbling to myself as I turn the camera around in the mount.) |
