Go to Post I think being successful in FIRST is creating an environment where people can grow, learn, change, and recreate... It's about making an environment where kids feel they can be successful... in whatever discipline they choose. - ColleenShaver [more]
Unread 12-01-2006, 12:34
Max Brin Max Brin is offline
FRC #1943 (Neat Team)
Max Brin has a spectacular aura aboutMax Brin has a spectacular aura aboutMax Brin has a spectacular aura about
Batteries on robot
Can we use 2 batteries on the robot?
Do we have to buy exacly the same batteries as supplied with our kit?
Thanks & Good luck!
Unread 12-01-2006, 12:42
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: Batteries on robot
You can own as many spare batteries as you want, as long as they are the same part as in the kit, but you can only have one at a time on the robot.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 12-01-2006, 12:43
Elgin Clock's Avatar
FRC #0237 (Black Magic)
One is incorrect.
At any given time while competing, One 12v main battery & One 7.2v backup battery that plugs directly to the RC. 2 batteries, different Voltages.
You may buy more batteries to have on hand, but they must be of the same specifications of the supplied KOP batteries.
Ie: no 9v batteries on your robot powering anything "functional".
The only exception to this rule (and someone correct me if it changed since last year) is the use of a battery to power a non-functional decoration.
I could be wrong about that last part though... Check the Manual, under Robot, and the Electrical section of that.
Unread 12-01-2006, 12:46
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
<R51> The only legal main source of electrical energy on the robot is one of the two 12v DC non-spillable lead
acid batteries provided in the Kit of Parts, or a spare of the same part number. The 7.2v “backup” battery is
considered an integral part of the Robot Controller, and may not be used for any other purpose. The only 12V
battery that may be used on your robot during competition (Friday and Saturday) is the Exide model EX18-
12. (Additional EX18-12 batteries may be purchased through your local Exide supplier.) You may use other
equivalent 12V batteries during Thursday practice rounds.
Unread 15-01-2006, 21:50
Rick Thornbro Rick Thornbro is offline
#0217 (ThunderChickens)
Rick Thornbro will become famous soon enoughRick Thornbro will become famous soon enough
Just out of curiosity, why would you want to use a second battery? They weigh 10-13 pounds a piece.
Unread 15-01-2006, 22:07
Sscamatt's Avatar
Sscamatt Sscamatt is offline
AKA: Matt Syska
FRC #0195 (Cyber Knights)
Team Role: Electrical
Sscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud of
Send a message via AIM to Sscamatt
The battery isn't included in the weight of the robot.
2006 Championship Finalist, Thanks 25 + 968!
2006 Newton Division Winner
2006 International Innovation In Control Award
2006 Radio Shack Innovation in Control Award, UTC Regional
RIT Class of 2011
Unread 15-01-2006, 22:16
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Either to run things at higher voltage (Hard to do safely without frying things) or simply longer life. These robots chew up a heck of a lot of power. It's not unheard of for robots to completely drain a battery in a single game!
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 16-01-2006, 00:20
Bharat Nain's Avatar
Originally Posted by Elgin Clock
One is incorrect.
The 7.2 volts backup battery is technically considered as a part of the control system. Therefore, it is not considered a battery at all at inspections. And no, you may not have more than one of those on your robot at a time.
Conclusion: You can run your robot/have only one 12v and one 7.2v battery at a time.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 16-01-2006, 07:43
Just to add to this post (even though it has been discussed ad nauseum before) it is true that some teams drain a battery in one match. Unfortunately that points to an inefficient mechanical design. The battery for an efficient 120 lb robot design should last more than one match and many last three or four before needing a recharge. Even good designs can have some problems (loose bearings, axles out of alignment and extreme side loads on motors or transmissions) that eat battery. It is wise to check your current draw with a current meter (Amprobe or Ampclamp) to determine your running current draw. If it should be higher than previous testing, look for a mechanical problem.
Winning Robot or Quality Robot? Eric Bareiss General Forum 30 09-02-2006 13:19
Honda's robot... Don Wright Math and Science 7 17-12-2005 13:15
Keeping batteries during shipping Andy Brockway Rules/Strategy 4 17-02-2005 17:37
Batteries Exide 2005 Quanity Mike Martus Electrical 6 13-01-2005 19:44
Robot Collaboration Karthik General Forum 153 18-02-2004 03:40
