Go to Post Finally, they're getting rid of the spotlights. I'm sick of seeing ridiculous inside jokes up there. - Karthik [more]
Unread 16-01-2006, 10:49
AUWarEagle#1's Avatar
AUWarEagle#1 AUWarEagle#1 is offline
FRC #1611
AUWarEagle#1 is an unknown quantity at this point
Vision Target power supply
Is there a manual anywhere that tells you how to wire up the power supply to the Vision Target.
Unread 16-01-2006, 10:58
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Vision Target power supply
check out
http://www.chiefdelphi.com/forums/sh...ad.php?t=41362
-Michael Dessingue
Unread 16-01-2006, 11:05
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The white wires out to the cold cathodes plug into the wider ports on the cathode transformers. The red and black wires plug into the smaller ports on the transformers. Then connect the red and black wries to a 12 Volt power supply. The red wire is +12V and black is ground. Either find a 12V AC-DC converter around your house, or alternatively use an old PC power supply. On a PC power supply, the yellow wire goes to the red wire on your cathode transformer, and the black wire goes to the black wire. You can hot-wire the power supply by putting a bit of wire between the green wire on the giant connector to any of the black wires.
Note: This advice is from someone who was bright enough to produce a 5V to ground short through his team's CMUCam by being clever with a PC power supply.
Unread 18-01-2006, 22:17
FreakyAntelope's Avatar
FreakyAntelope FreakyAntelope is offline
Unregistered User
AKA: Toby Waite
#0246 (Overclocked)
Team Role: Electrical
FreakyAntelope will become famous soon enough
Send a message via AIM to FreakyAntelope
Or, if you don't feel like messing with a power supply (or don't have one), you can just hook it up to one of the 12 volt robot batteries.
That's what we did anyway, on a long cord with a switch by the anderson connector.
- Toby
vision target Dakota Snow Kit & Additional Hardware 1 08-01-2006 23:00
Circuit design help - power supply - Non FIRST Josh Siegel Electrical 31 24-12-2005 13:47
Additional basic stamp servo power supply John Gutmann Electrical 11 21-09-2005 21:45
power supply of control system archiver 2000 5 24-06-2002 00:14
