Go to Post EVERYONE on the team is offered the same opportunities to be a team player, it is up to each person to step up and play the game. - MariaCastro [more]
Unread 16-01-2006, 13:35
Max Brin Max Brin is offline
FRC #1943 (Neat Team)
Max Brin has a spectacular aura aboutMax Brin has a spectacular aura aboutMax Brin has a spectacular aura about
Chassis Changes
Can we change the chassis or is it a deafult one?
We built the one that was in the PDF file at usfirst.org
Thanks & good luck!
Unread 16-01-2006, 13:39
Bharat Nain's Avatar
Re: Chassis Changes
You can build any chassis you want. Take a look at the technical White papers section. Also look at the Picture Gallery for more examples. Feel free to ask more questions.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 16-01-2006, 13:42
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Chassis Changes
You may change it however you like. Or even build a completely new one!
Unread 16-01-2006, 13:44
REVving up for a new season
FRC #2848 (All-sparks)
Re: Chassis Changes
you are allowed to make any modifications to the chassis that you wish. Actually you are required to to fit the size restrictions of 28 x 38. Good luck
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 16-01-2006, 16:14
in between teams
AKA: Luke Van Oort
Re: Chassis Changes
As previously mentioned, you can do whatever you want. But, always keep a connection with reality, a custom solid carbon fiber frame may win awards, but is it worth the trouble. On a more likely note, that powder coated 80/20 extrusion or welded aluminum frame may be a bit stiffer, lighter, or cooler than the kit, but the kit one is very adaptable. Given, it definitely needs stiffening, but you can have a very capable chassis with the sole addition of a round or square aluminum extrusion X-brace and higher traction wheels.
Team 1219: 2009 - Mentor
Unread 16-01-2006, 17:53
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Chassis Changes
Also, the metal provided in the kit doesn't have to be used for the frame. Be creative!
Vision Target Chassis Mod? AnkurG Kit & Additional Hardware 1 08-01-2006 21:12
Input On Steel chassis w/wood inset Henry_Mareck Technical Discussion 36 20-12-2005 14:52
MXR 1120 Chassis & Wheel Hub MXR1120 Robot Showcase 4 26-01-2005 00:33
KOP Chassis & Transmission Support/Documentation JVN Technical Discussion 0 10-01-2005 00:28
the provided chassis material Andrew Dahl Kit & Additional Hardware 5 09-01-2003 15:26
