Go to Post If any of these alliances happen, I think i'll eat my computer. - Anupam Goli [more]
Unread 14-01-2006, 21:00
jdong jdong is offline
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
jdong will become famous soon enoughjdong will become famous soon enough
Re: Labview problems and code problems
Originally Posted by Ryan O
I'm not sure if I need the Labview drivers for the camera. the disk got scracthed and I can't install the them. Do I need them? If I do, where can I get them? Any help would be great. Thanks for the help with the COM ports, by the way. I was able to get them working using your tips.
YES -- you need to install the NI-VISA software off the Driver CD #1. Otherwise serial will not work.
John Dong
Co-Captain, Webmaster / Programmer
Team 245 -- Rochester Adams Robotics
Unread 15-01-2006, 15:46
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
You can also get NI-VISA here.
-Joe
Unread 16-01-2006, 14:00
cmurdoch cmurdoch is offline
AKA: Caroline Murdoch
FRC #1208 (Metool Brigade)
cmurdoch is on a distinguished road
ok new problem. The mount assembly instructions show the camera mounted with the power switch toward the bottom. I was able to successfully grab frame using last year's GUI program, but now that I'm using the Labview GUI, the frames are upside down. Why? Is the camera supposed to be mounted the other way?
Unread 16-01-2006, 15:24
Excelsior's Avatar
Excelsior Excelsior is offline
Electrical Head
AKA: Alex Hughes
None #1208 (Metool Brigade)
Team Role: Electrical
Excelsior is on a distinguished road
Send a message via AIM to Excelsior
It's problems like these that make me glad to be Electrical. Good luck to you all.
Team 1208
The Metool Brigade
Three Hours Short of Going Insane
0=====<(' '<) <( ' ' )> (>' ')>=====0
Unread 16-01-2006, 15:42
I've reversed the way the camera is mounted and now it will track correctly vertically but the tracking is backward horizontally. I seem to recall reading something about jumpers that invert the tracking but I don't remember where. Please Help.
Thanks
Unread 16-01-2006, 16:10
Thanks
In this image the jumper position to reverse the servo action is listed at the bottom as "Pan Reverse". You need to add a little suitcase jumper to connect the two pins there.
Unread 16-01-2006, 16:29
double_check's Avatar
double_check double_check is offline
AKA: Amanda
FRC #0692 (The Fembots)
double_check is an unknown quantity at this point
Send a message via AIM to double_check Send a message via MSN to double_check Send a message via Yahoo to double_check
We are getting an error message that reads "The application is closing because of a reported error. You should confirm that the correct serial port has been selected. You should confirm that the camera has power and is connected to the PC via serial cable." Does anyone have any idea how to fix it? We have the CMUCam 2 demo up and the GUI file among others. We have NI-VISA is loaded so that is not our problem. Help, please.
2003 UC Davis Regional Winner
2003 UC Davis Motorola Quality Award
2003 UC Davis Daimler Chrysler Spirit Award
2005 UC Davis Quarter Finalists
2005 UC Davis Daimler Chrysler Spirit Award
2006 UC Davis Imagery Award
"Normal is only a setting on washing machines and dishwashers." - Anonymous
Unread 17-01-2006, 01:07
AKA: jhersh
If you get that message, then an error cluster popped up on the upper right side of the screen. Please post what that error is... Both the error number and the message. Most often it's because you didn't pick the correct serial port from the dropdown box on the upper left. The other notes in the error message apply as well. What have you tried / verified?
Good luck!
-Joe
Unread 17-01-2006, 01:10
AKA: jhersh
Thanks
The camera definitely should be mounted with the power switch up. I think the instructions are probably an intentional typo to keep you on your toes. Kind of like the incorrect motor specs of previous years. Don't trust blindly... verify and validate. Always check for sanity in the information you are given.
Good luck!
-Joe
Unread 17-01-2006, 01:22
b_mallerd b_mallerd is offline
Programmer
FRC #1346 (Trobotics)
b_mallerd is on a distinguished road
Send a message via MSN to b_mallerd
Did you check that your camera actually has power? We were stuck for a while because we didn't know you had to hook up the main battery and the pwm out ports were not giving any juice. The camera have led's to tell that it's on. Also, you might want to make sure that your ttl port is disconnected. The ttl and the serial are mutually exclusive (You can only plug in one or the other). Lastly, make sure you have the right serial port...Go right click on my computer, properties, hardware, device manager. Then go to the expandable tree for serial devices or sumthin and check that you have the right COM port.
Unfortunately i know all this from experience
Unread 18-01-2006, 17:07
Ok now we have the labview application and the tracking is working beautifully (it's even tracking green now not white like it used to be). The default code is working without a hitch and it's searching and returning values to the screen like it's supposed to. But... oh yes there's always a but... I can't get it to actively track using the default code. I've found the code that causes it to track (tracking.c... hooray for logical naming) but I can't find where that code is initialized or how to get it to run. I'd also like to know how to retrieve the tilt and pan values so I can actually put them to use in the program. I might be missing something really obvious, but I'd appreciate some help.
Thanks
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Code problems doyler Programming 14 15-02-2005 16:23
Wierd gyro code problems...pls help Salik Syed Programming 4 14-03-2004 01:29
IR reflective (tape) sensor code problems Argoth Programming 8 07-02-2004 21:32
