Re: Chassis Changes
As previously mentioned, you can do whatever you want. But, always keep a connection with reality, a custom solid carbon fiber frame may win awards, but is it worth the trouble. On a more likely note, that powder coated 80/20 extrusion or welded aluminum frame may be a bit stiffer, lighter, or cooler than the kit, but the kit one is very adaptable. Given, it definitely needs stiffening, but you can have a very capable chassis with the sole addition of a round or square aluminum extrusion X-brace and higher traction wheels.
| Vision Target Chassis Mod? | AnkurG | Kit & Additional Hardware | 1 | 08-01-2006 21:12 |
| Input On Steel chassis w/wood inset | Henry_Mareck | Technical Discussion | 36 | 20-12-2005 14:52 |
| MXR 1120 Chassis & Wheel Hub | MXR1120 | Robot Showcase | 4 | 26-01-2005 00:33 |
| KOP Chassis & Transmission Support/Documentation | JVN | Technical Discussion | 0 | 10-01-2005 00:28 |
| the provided chassis material | Andrew Dahl | Kit & Additional Hardware | 5 | 09-01-2003 15:26 |
