Go to Post CD is not the GDC. (Otherwise we'd be better at getting the game hints! ;) ) - Ninja_Bait [more]
Unread 15-01-2006, 21:06
occra 23.
AKA: ryo
None #1481
Re: Turbulence
Originally Posted by Tatsu
We talked about this, the best way would be to get a commercial leaf-blower and gut out the insides, replacing the motor and creating a compatibility gearbox.. you'd get something like 220 mph winds upward..
if so.. think more Normal force..... =..... unpushable robot?
actually i think its impossible to get a 220mph air current...... i dont see how you got that number.
Unread 15-01-2006, 21:45
Zach Purser's Avatar
Zach Purser Zach Purser is offline
AKA: Gumby
FRC #0435 (Robodogs)
Zach Purser is a jewel in the roughZach Purser is a jewel in the roughZach Purser is a jewel in the rough
Send a message via AIM to Zach Purser
Re: Turbulence
Has anyone tested using a leaf blower to launch the balls? Most people report the balls as being just under 7" so you could feasibly use 7" ductwork as a cannon. Creating a sealed system might be a little more tricky.
As far as feasibility, I don't think you'll get 200mph, but it seems that if you attach a globe motor to a blower you'd get a pretty good amount of air. Maybe the results would be similar to this blower:
http://www.makitatools.com/menu.php?...et&tag=UB181DZ
If anyone could dig up a spec sheet on the motor in this blower we could compare it to the kit motors.
Unread 16-01-2006, 00:17
I'mwithstupid^'s Avatar
I'mwithstupid^ I'mwithstupid^ is offline
I'mwithstupid^ is on a distinguished road
Re: Turbulence
how does using suction take up an more power than blowing???????? the air that comes out of the blowing end had to come from some where! so if it shoots out of a collar at 220 mph, if u switched the direction of the rotation of the fan than it should suck at the same speed.
Unread 16-01-2006, 04:35
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Re: Turbulence
I assume with sucking you'd want to grab the ball for yourself. With blowing you only wanted to knock it off course. The robot hopper is a much more specific location than "anywhere but the goal". And even if you could pull the ball into your robot you need even more power, or less simple design, to keep it there. i can just imagine the ball bouncing off and going into the goal anyway
Unread 16-01-2006, 14:22
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
Re: Turbulence
220 mph is the leaf-blower I own.. thats where I got that number.. I think if you use 2 of the big CIMs, and create a gearbox, that number might be feasible .. but of course I suspect this will drain the battery faster than any other design.
Unread 16-01-2006, 15:05
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Re: Turbulence
You know how pneumatic wrenchs work? why not do that? get the pressure from the pneumatic tank and input it to a mini fan that extends out to larger propellers.
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 16-01-2006, 16:04
in between teams
AKA: Luke Van Oort
Re: Turbulence
I thought of another benefit of sucking. If you blow then your column of air will invariably point towards the goal, unless you're off to the side. So, if a team gets a ball in the column they score and you look stupid. So, maybe this should be an offensive strategy.
Team 1219: 2009 - Mentor
Unread 16-01-2006, 16:16
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: Turbulence
I don't think sucking air would be nearly as efficient as propelling it. When air get pushed out it looks like a mushroom (I know not exactly but thats as close as i can describe). When sucking air however, air from all around will rush to fill the vacuum. Hardly something you can aim, think how powerful vacuums are but how short their range is.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 16-01-2006, 19:37
Re: Turbulence
The concept used to explain what you're talking about is "entrainment". Blowing air will drag more air along with it, moving a lot more than just what the fan is capable of. Sucking air doesn't get the same benefit.
