Go to Post Build a student a robot and it will keep him/her busy for a few days in the spring. Teach a student how to build(design, wire, program) a robot and they will stay away from home, use some really strange language and wear funny clothes the whole year long. - Al Skierkiewicz [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 16-01-2006, 16:41
SkiRacer SkiRacer is offline
Measure once, cut twice
AKA: Andrew
FRC #1676 (Pi-Oneers)
SkiRacer is an unknown quantity at this point
Send a message via AIM to SkiRacer
LabView Gear Tooth Sensor Code
Does anyone have the code that LabView needs to link with the gear tooth sensor?
Unread 17-01-2006, 00:26
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: LabView Gear Tooth Sensor Code
The gear tooth sensor was not meant to be used with the USB-6009 DAQ device the same way it will be used on the robot. The gear tooth sensor generates a pulse that is too narrow for a USB DAQ device to read reliably - most often on the IFI controller teams use an interrupt line to catch pulses and to reduce aliasing of the pulsing signal. No such mechanism exists for the USB-DAQ. However, if you were to use a standard Hall-effect sensor (without direction sensing), the DAQ can be used to read the output of the sensor at low speeds.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 17-01-2006, 03:53
Joe Hershberger Joe Hershberger is offline
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
The USB-6009 does support one simple event counter on PFI0 that you could use to count pulses. This would not give you direction information, though. The way you would use this is to use a timed loop in LabVIEW and each time your loop executes, look at how many pulses you measured and divide that by your timebase. This would work well as a basic interface to validate functionality, but it would not be very flexible.
Good luck.
-Joe
Gear tooth sensor vs. Optical Encoders Avarik Programming 7 17-01-2006 10:18
National Instruments LabVIEW and Data Acquisition Forum Danny Diaz National Instruments LabVIEW and Data Acquisition 1 16-01-2006 13:20
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
gears Michael Leicht Inventor 12 16-09-2004 10:52
Coupling the drill motor with out the 15 tooth gear Chopper_Dave Motors 1 17-01-2004 01:06
