Go to Post The card system worked. Well. It was used properly and (except for when Paul yellow carded Andy during his "Thank you" speech) wasn't abused. I applaud the referees. Kudos. - Collin Fultz [more]
Unread 16-01-2006, 19:08
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Can We Use a Bicycle Tire and Rim?
Can we use a bicycle tire and rim for our robot shooter?
Waialua, HI 359
Last edited by Mike Schroeder : 16-01-2006 at 19:30. Reason: removed tags from title
Unread 16-01-2006, 19:27
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: [B]Can We Use a Bicycle Tire and Rim?[/B]
I don't see why not. It seems to be legal after looking at the flowchart provided in the manual.
For future reference, the rules can be found at http://www.usfirst.org/robotics/2006/frcdocs.htm. Get to know them. They are your best friend!
JBotAlan
Aren't signatures a bit outdated?
Unread 16-01-2006, 19:30
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Re: Can We Use a Bicycle Tire and Rim?
I'm not sure on the ruling of that, but I don't think that it would be that great.
If the bot is ~120lbs with ~15lbs of bumpers, I doubt bike tire spokes will be able to support it.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 16-01-2006, 19:33
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
The way I understood it was they want to use a flywheel-type design with the bicycle wheels as the flywheels. I see no problem with this. They could, according to the flowchart, use the wheels as the drive wheels, too.
Unread 16-01-2006, 19:37
Andrew Blair's Avatar
FRC #0306 (CRT)
Well, if they did decide to use it, I'm sure it would hold up fine. A bike weighs fifteen pounds, the average weight rating on a cheap bike is 180 lbs. Seems alright to me. Actually, there was a team who did use bike tires one year. Sorry, don't have the pic.
-Sir Francis Bacon
-Albert Einstein
Unread 16-01-2006, 20:05
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
You should be able to provided you can keep it entirely withing the starting robot dimensions as stated in rule <S03>.
Unread 16-01-2006, 20:24
bike wheels are very strong if the weight is kept perpendicular to the axle. When you ride a bike you lean into turns, so the weight load stays on that line
but they are not good with side-loads. Long story, ask me sometime! :^)
Unread 16-01-2006, 21:53
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
Bike tires are awesome. The spokes are almost strings they are so thin. In fact... a fun project (after build season) is to make a SAMPLE bike tire out of actual string. It works! (But don't use it...)
Brian Graham
Unread 16-01-2006, 22:25
EricH EricH is online now
I'm about 160 pounds. My bike is about 15 pounds. That's about 175. The robot is 150 max (with battery and bumpers). 'Nuff said.
Unread 16-01-2006, 22:39
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Ahh one thing that hasn't been talked about here. Safety.
Remember how in the kickoff video, they had the softball shooter, that had a big flywheel and they talked about it a little bit. One of the things they talked about was safety. It's fully legal, just make sure however you fit it into the robot it'll pass all the safety standards that first has in place.
Safety First everyone, you don't want to have your robot fail inspection because you forgot to make it safe. Also take safety into consideration while your designing too, make sure you allow room and weight for it.
Unread 16-01-2006, 22:40
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Bicycle wheels are definately strong enough to hold up a robot, especially when the weight is divided upon all 4 wheels. Depending on the wheel, they can be strong on side loads too.
Why are you choosing a bik wheel for a shooting device though? Most wheels are free spinning, and most back wheels from bikes have coaster hubs. Unless this is part of a secret strategy...
Unread 16-01-2006, 22:42
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I'd be more worried about losing a finger, or a head of hair!
Everyone please keep in mind how much potentially dangerous energy a spinning flywheel has. And do not wear gloves while rowkiong on/near rotating machinery/mechanisms.
Unread 17-01-2006, 00:43
nexusmaster nexusmaster is offline
Poof Squishy= omg HAHA
AKA: Ken
FRC #1717 (DPengineering)
nexusmaster is an unknown quantity at this point
My understanding is that bike tires are indeed legal, but if your robot takes a solid shot to the side I think that there is a good chance that the bike tires will deform and become useless. The spoke design is one that assumes the outside forces will be vertical to and not perpedicular to the spokes. However, I could be wrong. It might be a good idea to stress test a bike tire and collect some data.
Unread 17-01-2006, 07:38
Nope, not falling into that one again.
Unread 17-01-2006, 07:50
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
First I weigh 180 and and ride wheels with 20 radial spokes, so strength isn't an issue on a bike wheel.
Second a fairing fopr the wheel could be made out of 1/32 polycarb to keep fingers out of spokes.
Third the OD of a road bike wheel is 700mm ~ 29 inches. That is reeeeeeally big.
Oh and you can get a pair of inexpensive wheel in the 1400gm range easily.
