Go to Post GP is asking for something then having twenty people answer graciously. - synth3tk [more]
Unread 16-01-2006, 03:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
3/4" bore x 1/2" stroke Bimba Cylinder model
Does anyone have a good Inventor model of this cylinder?
EDIT: Also, if anyone happens to know the thread on the front of the body of it, that would be great.
Unread 16-01-2006, 03:56
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
Re: 3/4" bore x 1/2" stroke Bimba Cylinder model
i just modify the actuator from the KOP on www.firstcadlibrary.com, then just resize the actuator to the size i need it. If you want the lazy way to it, than i cant help you.
Unread 16-01-2006, 08:39
REVving up for a new season
FRC #2848 (All-sparks)
If you go to www.bimba.com and click on the CAD tab then choose your software, click "non repairable stainless steel cylinders", then click original line, select your bore size, then select your mounting option (for FIRST i believe you want the 04-DP, then plug in your stroke size and the model will generate itself for downloading.
Hope this helps.
There is another website (aircylindersdirect.com) that has a similar cad generator but i would trust the bimba one more.
Greg
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 16-01-2006, 08:42
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
If you insert the i-CylinderBody model from the FirstCadLibrary into an assembly, a dialog box will pop up that asks you to pick the size of the cylinder you want. 3/4" x 1/2" is #1 in the table.
Ed Sparks
MECH TECH FRC-3959
Unread 16-01-2006, 22:00
Thanks. The body looks pretty good. I was hoping for a shaft too, but I'll wait until I can see one again in person and then do it.
Important: Does anyone know what thread is on the front end of the body of the cylinder? Thanks so much.
Unread 16-01-2006, 22:14
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Check the Pneumatics Manual!
1/4''-28 for the shaft.
5/8''-18 for the body.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Same bore, same stroke, same mounting--is it legal? Billfred Pneumatics 2 20-02-2005 00:41
24" Stroke 1.0625" Bore Piston Legality Yan Wang Pneumatics 4 05-02-2005 09:32
Need Inventor model 3/4" Bore Cylinder Quick sanddrag Inventor 1 05-04-2004 00:40
Stopping a Piston... Dan 550 Technical Discussion 7 02-02-2002 11:36
