Go to Post Next year they should make Roombas the game piece. They're not very effective at vacuuming the rug that's for sure. - Koko Ed [more]
Unread 16-01-2006, 00:27
Team1726Nerds's Avatar
Team1726Nerds Team1726Nerds is offline
electical/mechanical
AKA: Thomas Brown
FRC #1726 (N.E.R.D.S.)
Team1726Nerds is an unknown quantity at this point
Large Papst Fan Sensor
For those of you who got the model 4112N Papst Fans with the third wire, it is a temperature sensor. Here is a helpful link: http://www.papstplc.com/features/articles/art012
What i'm really writing this post for is to ask if anyone has tried incorporating this sensor into their robot controller. I know it's not crucial and the fan does not draw too much power, but our team was going to play with it and see if we can get it to work. So anyone have any experience?
Unread 16-01-2006, 00:46
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Re: Large Papst Fan Sensor
what type of value does it output?
analog then you have to figure out what is the temperature to the A/D converter ratio.
you are going to have to drive the fan of a speed controller because the robot controller can't provide the 12v.
This is not to put you down but rather to tell you its a bit complicated.
Unread 16-01-2006, 16:04
Andrew Blair's Avatar
FRC #0306 (CRT)
Interesting. Are these fans the metal ones? Generally speaking, the fans don't draw too much current, so having them run all the time isn't a big deal.
-Sir Francis Bacon
-Albert Einstein
Unread 16-01-2006, 16:15
Umm Errr...
I always figured that was a tachometer wire.
1139 Alumni
Unread 16-01-2006, 22:48
AKA: Thomas Brown
It seems like it'd be a PWM signal from what i got from the PAPST website. We were thinking about hooking it up to an oscicallscope to test it out. I know that it's not really necessary, but our team was just wondering.
Making a Sensor Board SpaceOsc Technical Discussion 11 15-05-2004 12:46
wiring the optical sensor bob1million Electrical 2 24-01-2004 11:00
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
Sensor use on Papst Large Fan archiver 2001 6 23-06-2002 23:14
