Go to Post There's more than one way to skin a cat. - Al Skierkiewicz [more]
Unread 16-01-2006, 17:57
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Re: pneumatic launch velocity
Originally Posted by KenWittlief
an 11" lever with the pivot point 1" in from one end will have a 10:1 multiplier
ten times the distance (speed) on one side vs the other, with 1/10th the force available.
Is this a mechanical lever or is some kind of pneumatic device, because I am seriously lost.
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 16-01-2006, 18:32
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
See attached.
Unread 16-01-2006, 18:50
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Ahhh! what if you were to take that 1" stroke piston 2" diameter and fire it directly to the ball. Would that be enough to fire it to the center goal??
Callsign: N6ARA
Unread 16-01-2006, 20:07
probably, if you have enough pressure in the cylinder
and you preload the cylinder with pressure, and use a mechanical release like I talked about on page one
the only caveat, a 1" piston throw may not deform (dent) the ball enough to transfer all the energy quickly. You might need a bowel shaped plate to keep the ball from deforming as the cylinder punches it.
a 1" piston throw into a 1:10 lever: definitely!
Unread 16-01-2006, 20:09
Umm Errr...
wow... Release latches, lever linkages etc.. Yall are making this way too complicated.
1139 Alumni
Unread 16-01-2006, 20:10
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Do you have some alternative to offer?
--Madison--
...down at the Ozdust!
Unread 16-01-2006, 20:21
as complicated as it needs to be.
Pnuematic shooters have some definate advantages:
+ The tank can be precharged before the match starts (a wheel must be spun up before it can launch a ball)
+ a pnuematic cylinder with a release pin is much simpler to build and mount than a motor/gearbox/wheel
+ much smaller
+ much lighter
+ the pressure control is simple: the regulator valve is very accurate
+ you can cycle pnuematics really quickly.
I think we will definately see pnuematic launchers this year, in many configurations.
Unread 16-01-2006, 20:22
Umm Errr...
Well yes but thats a secret
Think about how you can maximize the airflow to the cylinders. Think about what sizes will move fastest. Think about all that wasted energy on the return stroke.
1139 Alumni
Unread 16-01-2006, 23:23
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
This is going to be honestly more of a hunch, so your mileage may vary*, but I'm going to say outright that I think there will be some velocity damping going on in these cylinders, and I'll venture to say that there just won't be a 12 m/s end velocity on these cylinders. Someone can feel free to do the math, but accelerating to 12 m/s in 1 inch...
Oh sheesh, I'll do the math
v^2 = 2 * a * d
(12 m/s) ^ 2 / (2 * 1in / 39.37in/m) = a
a = 2834.6 m/s^2
so... 1/2 * a * t^2 = d
t = sqrt ( (1/39.37) * 2 / 2834.6)
t = 0.004 seconds.
I'll say (from experience) I haven't seen pneumatics move 1 inch in 4 milliseconds. I think there's a lot of time required to have adequate airflow from the tanks to the piston, and like I alluded to before, I really think there are vicious damping issues that arise.
Hence, it's my personal recommendation that you do not count on having a directly driven ball launcher using a pneumatic cylinder. However, I feel pretty confident that you could come up with something with some mechanical advantage ideas that was previously mentioned.
Matt
* an admittedly stolen disclaimer of Dr. Joe. Imitation is the greatest form of flattery.
Falcon 1 Ready to Launch Friday 11/25 Doug G Chit-Chat 2 26-11-2005 22:04
NASA Schedules Robotic Spacecraft Launch Mirza95vx General Forum 2 07-04-2005 00:33
Pneumatic Wheels Steve P Pneumatics 4 07-02-2005 15:16
Pneumatic Gripper ruling Nitroxextreme Pneumatics 7 30-01-2005 13:04
Who has used pneumatic wheels? chellyzee93 Kit & Additional Hardware 3 16-02-2003 11:49
