Re: Strange Problem, varible not subtracting?
Hi Matt, Thanks for the time in checking this out. We don't want to set that varible first, or before the math. It is true that the first loop through the CPU it will be ZERO. But then it gets a value (50) at the bottom on the first loop. Shouldn't the CPU remember this value, so in loop pass #2, now that varible is set to 50 and it should correctly excute the subtract math? We only want to update this varible at the end because we are doing a velocity measurement sampling the encoder counts. I posted Screen 1 through 4 to show you what we are trying to do our testing, basiclly to eliminate "Have you tried this? Have you tried that?" Sort of thing.... Screen shot #5 is what we want, but we found out the problem in screen shot 3 and 4. By the varible updating but not being able to get subtracted above it. Last edited by Chris_Elston : 17-01-2006 at 00:24. |
If you want to reuse the value of enc_Right_Old_Count, one way is to return this value from your function and then send it back as an arguement each time its called in your main loop. This is where... my syntax experience with C gets foggy. If you want to return and reuse both parameters, I think you'll actually need to return them as an array, since you can't return more than 1 variable from a function. You'll need to make a 2 element array, return them and if you wish for cosmetic reasons, split them up. Some brief example code inside the function right_velocity would be: Code:
long velocity_right(enc_Right_Old_Count)
long distance_and_old_count[2]; // declares this array
** MATH **
distance_and_old_count[0] = enc_Right_Difference;
distance_and_old_count[1] = enc_Right_Old_Count;
return distance_and_old_count;
In the main outter loop, you would use something like the following to send the en_Right_Old_Count value to the function: Code:
distance_and_old_count = right_velocity(enc_Right_Old_Count); enc_Right_Difference = distance_and_old_count[0]; enc_Right_Old_Count = distance_and_old_count[1]; Last edited by Matt Adams : 17-01-2006 at 01:15. |
Use global variables if you want variables to be persistent through many function calls.
| Need a realistic Statics Problem | sanddrag | Technical Discussion | 10 | 05-12-2005 15:07 |
| Strange system problem | Bill Becker | Control System | 16 | 12-04-2005 17:19 |
| Strange Multi-Turn Potentiometer Problem | Yellow Eyes | Electrical | 10 | 24-02-2005 13:53 |
| Strange Encoder Problem | AIBob | Electrical | 3 | 20-02-2005 22:20 |
| Strange Auto Problem | NotQuiteFree | Programming | 6 | 20-02-2005 17:12 |
