Go to Post Hey, I know that kid.... wait he is my son! - Mike Martus [more]
Unread 17-01-2006, 02:58
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Re: Speed Ramping with Deadzone
Originally Posted by Rickertsen2
Last year we did the following with great results:
1.)lift your robot on some blocks. Write some code that steps gradually through each pwm value and use some sort of wheel speed sensor to create a table of PWM vs. speed. Do this for each drivetrain module.
2.)write a lookup table that makes things linear
3.)The deadzone that is built into the speed controllers has now been eliminated so you will need to code your own. Do so.
This works well to smooth out the nonlinearity wherever it comes from, and make your drivetrain drive straighter. Short of closed loop feedback, i think this is the best approach
Rick,
That's definitely a great way to make the robot feel more responsive. When we create out linearization map, we strapped a laptop on the robot and had the debug port read the wheel speed off of the encoders. We programmed it to, very similarly, output each pwm code in succession and report on the speed. However instead of using blocks, we did one wheel at a time and had it drive in a circle. It got pretty crazy at the highest speeds. Our drive system had only two drive wheels on the ground and 2 omni castors so we didn't have trouble with side load from turning. This allowed us to get the total system response when loaded as opposed to unloaded on blocks.
I think this year we'll use the BlueSMiRF and spare the risk to the spinning laptop!
It was incredible how non-linear the response was. The inverse table improved drivability and responsiveness dramatically. Attached is a plot to show just how bad it was.
Cheers!
-Joe
Electronic Speed Controllers for DC Motor Spindle Robotics Education and Curriculum 12 23-04-2005 09:18
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
