Go to Post Throw the programmers (or freshmen with duct tape depending on the state of your robot) in the trailer with the robot for the ride between events. Problem solved. :D - ASD20 [more]
Unread 17-01-2006, 03:27
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Re: Autonomous using encoders
Originally Posted by Avarik
Another method would be to implement checks while trying to run straight. Maybe after every 100 encoder counts, you would, at that point, get your robot to adjust by sending a forward signal to one side, and a 127 to the other. One the counts were equal again, you could try going straight once more.
Avarik,
Don't forget: just because the number of ticks on each wheel are equal doesn't mean that your path was straight. You need the ticks to alternate one wheel then the other for the straightest path. If you just correct every 100 pulses, then you drive sideways for 100 pulses, straighten the robot, then drive sideways for another 100 pulses.
In an extreme case, one wheel sticks and the other goes 100 pulses, so you turned, say 90 degrees. Then you correct and wait till the other sees 100 pulses. That straightens you back out but you have barely moved.
Cheers!
-Joe
A Warning to Human Players During Autonomous The Lucas General Forum 21 07-04-2005 02:29
Setting Autonomous Settings from OI Tom Saxton Programming 15 27-03-2005 11:45
Despite what IFI says, you can configure autonomous from OI... TedP Programming 19 31-03-2004 10:09
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
