Go to Post Gracious Professionalism is being embarrassed at an event by an underperforming catstrophe of a robot, yet standing and applauding for every award because you realize that as hard as you worked that season, the other team must have worked even harder to get their achievements. - Taylor [more]
Unread 14-01-2006, 10:47
Nimmy Nimmy is offline
also Head of Strategy\Translation
AKA: Nimrod Amir
FRC #1577 (SteamPunk)
Team Role: Animator
Nimmy is a jewel in the roughNimmy is a jewel in the roughNimmy is a jewel in the roughNimmy is a jewel in the rough
Send a message via ICQ to Nimmy Send a message via AIM to Nimmy Send a message via MSN to Nimmy
question about the corner-block rule
the rules state that blocking the corner goal on defense isn't allowed
I don't have the PDF open and I didn't find the exact specifics of the rule
is it blocking the corner goal as in standing on the corner-ramp
or anywhere in the area preventing other bots to get there?
just slightly confused
Unread 14-01-2006, 11:23
Eria4044 Eria4044 is offline
None #0935 (Railerobotics)
Team Role: Webmaster
Eria4044 is on a distinguished road
Send a message via Yahoo to Eria4044
Re: question about the corner-block rule
<G21> ROBOT incursion into the Corner Goal - Incidental incursion into the corner goal that occurs as the result of a ROBOT pushing balls into the goal is permitted, not to exceed a distance of approximately 3 inches. Intentional incursion, for example to use a ball gathering mechanism to drop off balls inside the goal, or extending a portion of the ROBOT through the goal opening to activate the ball counting system, will result in disqualification of the offending ROBOT.
That was all I could find in the manual about corner goal interference, but last I heard defensive robots had to keep 3 feet away from the corner goals. Maybe it has something to do with pinning (G24), which could conceivably trigger the ball counter inside the corner goal.
Here's the manual for you to see yourself: http://www2.usfirst.org/2006comp/Manual/4-The_Game.pdf
Team 935 web team captain.
The team website: http://www.railerobotics.com/
Unread 14-01-2006, 11:31
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Wrong. There is no rule stating that you can not block the corner goal. <G19> allows it and nothing prohibits it.
Originally Posted by <G19>
Field Interaction - ROBOTs may push or react against any elements of the field, provided there is nodamage or disruption of the field elements. ROBOTs may not grab, grasp, grapple, or attach to any field structure. If a ROBOT violates this rule, the head referee will give one warning. If the referee determines that team is disregarding the warning, the team’s ROBOT will be disabled for the remainder of the match.
Wetzel
Viva Olancho!
Unread 14-01-2006, 14:12
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
This is incorrect. There is no limit as to how close to the goals a defending robot can be. Robots are in fact allowed to enter the goals--up to 3"
<G21> ROBOT Incursion into the Corner Goal - Incidental incursion into the corner goal that occurs as a result
2001-2004: Team 100
2006-Present: Team 254
Unread 14-01-2006, 15:25
AKA: Nimrod Amir
Team Role: Animator
but isnt the fact that it is incidental incursion afect the penalty decision?
I mean maybe 'only allowed 3" in if they are infact pushing balls in'?
Unread 15-01-2006, 00:45
You seem to have done your homework here. You are allowed incidental-- not intentional--incursion up to 3 inches. If the incursion is intentional, or greater that 3 inches (about 6.5 cm for those who aren't used to the Engish system), it's a 5 point penalty.
Unread 15-01-2006, 02:01
sburro's Avatar
sburro sburro is offline
AKA: Joe
FRC #0663 (crusaders)
sburro will become famous soon enoughsburro will become famous soon enough
Send a message via AIM to sburro
To ask this question a second way, lets say I am on Defence. I park my robot in front of the ramp so the other team does not have access to the goal. I do not see a rule, but I might have missed it, that says I can not. I do think there should be a crease like in hockey around the goal. just my 2 cents
K.I.S.S
Keeping It Simple Stupid
Unread 15-01-2006, 02:32
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
I think its legal to park there.
I think the rule is mainly so no robots stick anything over near the human player, and so the ball-counting systerm does not record your robot as a ball
Unread 15-01-2006, 03:33
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
I think it's been covered elsewhere on CD, but I also think it's clearly asked/answered in the Q/A system. You can block the corner goals, just abide by the rules stated in the manual as stated in this thread aleady.
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
Unread 15-01-2006, 19:52
in between teams
AKA: Luke Van Oort
AHHHH! Scenario questions! Net+ flashbacks!
Seriously though, the game animation shows a robot doing this, so I assume it's legal. But do you want to? That leaves only one robot to defend against two... bad numbers. If you want to really lock an alliance down, pull a 71. Grab all three robots and drag them to the other end of the field. Although I think there might be a rule about grabbing other bots... something to do with non incidental out of bumper zone contact.
Team 1219: 2009 - Mentor
Unread 15-01-2006, 23:36
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
It all depends on robot capabilities. If they dont have a shooter, camping the two corner goals will totally eliminate any way for them to score. Also, if you can deprive them of balls, or they cannot pick them up off the floor, and they have to send 1+ robots back to their Human Player, its a numerically equal (or favoring you) situation.
Unread 17-01-2006, 07:27
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
If you do plan on parking in front of a corner goal, make sure you've got a very robust robot. I imagine the other team will be doing everything they can to move you out of the way. I think we'll see at least one robot with a pneumatic lift on each corner to raise the tires off the playing surface....
Hi!
Unread 17-01-2006, 07:37
Billfred's Avatar
Billfred Billfred is offline
Not quite--re-read <S04> in the Robot section. Those sorts of lifts, unless they can do it while remaning within 10 degrees of vertical, would be wedges, which aren't allowed.
Unread 17-01-2006, 12:48
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
I can imagine there will be plenty of bots that camp out in from of a lower goal. It's a pretty good strategy especially for rookie teams that might not have a great ball collector or ball shooter mechanism. I can also imagine that there will be lots of pushing matches with those "camp bots" in front of the lower goals. What happens if a bot trying to score pushes a "camp bot" into the lower goal past the 3" "incidental incursion" limit? If you have bumpers on your bot or a really low bot it might not be very hard to get pushed up into the goal opening past the 3". I am sure FIRST expects there to be lots of pushing matches in front of the lower goals but who gets the penalty points? The bot that broke the plane or the bot trying to score that pushed the defensive bot into the goal?
Unread 18-01-2006, 08:33
Taylor's Avatar
AKA: @taylorstem
I think you misunderstand my intention - I'm not considering tipping another robot. I'm thinking along the lines of a backhoe with the support struts to lift the tires off the ground so the machine will not roll when digging. Something to steady the robot and render it quite immobile, without wavering from vertical.
Anyway, it's an outside-the-box type of thing - we are not considering it for our own bot (I'm not gonna subject our second-year team to the world of pneumatics quite yet).
That's one of the wonderful properties of this year's game - a team could build a robot that is very aggresive both on multiple options of offense and defense, rather than concentrating on one aspect of the game.
Hi!
Ball Recirculation Question Nuts4FIRST Rules/Strategy 23 15-01-2006 15:35
Player station question... E Jones 234 Rules/Strategy 11 26-02-2005 02:37
Question of the Week!!! (10/11/04) Andy Grady General Forum 29 13-10-2004 08:13
Question of the Week!!! (8/24/04) Andy Grady General Forum 27 27-08-2004 19:00
