Go to Post I didn't say this! - Max Lobovsky [more]
Unread 17-01-2006, 08:35
RoboDriver's Avatar
RoboDriver RoboDriver is offline
AKA: ERIC
FRC #0326 (Xtreme Eagles)
RoboDriver will become famous soon enough
Question Will air pressure in venue affect path of ball? (was: DOES ANY ONE KNOW ????)
Does any one know that since the air pressure can affect the path of the ball does any one know if any of the following domes are pressurized the Eastern Michigan U Convocational Center or the Grand Valley State U Convention Center or the Georgia Dome?????
THINK IT...
DESIGN IT...
BUILD IT...
2008 GREAT LAKES CHAMPS THANKS 67 ,503
Unread 17-01-2006, 08:42
REVving up for a new season
FRC #2848 (All-sparks)
Re: DOES ANY ONE KNOW ??????????????
First, even if there was a pressure difference that might affect the ball trajectory ( which i doubt) every team would have to overcome the same situation so the field would be very fair.
next: i see that you are some what new to CD so if might be good for you to follow some of the the general rules for posting threads:
*Make a subject line that is relevant to the question being asked
*Typing in all Caps and Bolt is considered yelling and you get a much better response by being polite then yelling
*Please post your questions on the right forum. If this is a serious question about an event you should put it in the competitions forum, If this is a joke it should go in the chit chat forums.
i would also suggest that you read this thread and the respected threads linked in it. http://www.chiefdelphi.com/forums/sh...threadid=41221
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 17-01-2006, 12:08
kborer22's Avatar
kborer22 kborer22 is offline
kb
AKA: kb
FRC #0125 (Nutrons)
kborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud of
Send a message via AIM to kborer22
Re: Will air pressure in venue affect path of ball? (was: DOES ANY ONE KNOW ????)
this is something that we considered too, with a big venue like the Georgia dome..or any other for that fact there are some significant wind currents but i don't believe that they are close enough to the ground to affect the balls.From personal experience you can not feel the wind currents at field level ...one thing we are checking however is how and if humidity will affect the balls. We should have results on the swelling of the balls(if any) in a few days
NUTRONS 125
2007 Boston Regional Champs (125, 126, 69 NU-Hyper-Force!)
MORTTeam 11
2004-Palmetto Regional Champs
2004-Palmetto Regional Daimler Chrysler Team Spirit Award
2005-NJ Chairman's Award Winner
Unread 17-01-2006, 13:49
air pressure is only one variable that teams will encounter
do not plan to calibrate / adjust your shooting mechanics to swoosh balls through the center goal from 40 feet out at you facilities, and then ship the bot and expect it to do the same thing at every event
every team is going to need a way to tweak (fine tune) there shooters and launchers and foam nerfy ball flingers at the events.
Unread 17-01-2006, 14:37
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Also, I think just the way the nerf balls will get dinged, dented, sliced, mutilated and/or decapitated in competitions will have more impact on their trajectory than differences of at most only one PSI* or so of difference in air pressure.
* The difference of air pressure should not be that great. The difference in air pressure from the inside of a commercial jet to the outside environment at 35,000 feet is only 8 PSI. That's it. Even Denver, The Mile High City, has an altitude of 5,280 feet above sea level - or in other terms 1/7th the altitude of a cruising altitude for commercial airliners.
Also, because of the climate control in some buildings, the interior air pressure might be up to 1 PSI higher than the exterior air pressure. The reason for this is that the heating/air conditioning units put more air into the building that it lets out. This is true for a lot of skyscrapers in large cities. This might be true for some competition venues as well.
Art Dutra IV
世上无难事,只怕有心人.
Unread 17-01-2006, 23:02
occra 23.
AKA: ryo
None #1481
how do you define decapitated on a spherical object?
more than psi, temp, humidity, etc of the balls shooting, im more worried about the picking up part after hard matches the balls might be slipperier. smaller. abused. and well. since we dont have 6 robots to test with the major difference would be a more crowded area. but then again thats everyone the same. so it doesnt matter.
Nerf ball starting at 12m/s 45 degree angle ending at 8ft 6in w/ air resistance Ethulin Technical Discussion 39 14-01-2006 19:04
Need Help: Formula Needed Wilson Motors 21 30-12-2005 18:09
Blue Man Group FIRST get-together? Gui Cavalcanti Chit-Chat 11 16-09-2003 18:11
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
