Go to Post If mentors don't respect the students' desire to learn and take an active role in the construction, they're missing the point of FIRST. If students refuse to accept the knowledge and experience of the mentors, that's not independence - it's arrogance. - DB213parent [more]
Unread 17-01-2006, 10:51
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Re: CMUcam test rules...
Originally Posted by Terry Sherman
We tested out to 55 ft and tracked but we noticed our tracked blob size was 1 pixel so we're not confident that the racking is exceptional. We also noted the further away we went, the camera tilted less and less (as expected) but in an attempt to quantify it we noticed that ~45-55 feet we got the same angle feedback from the camera, so yes we could track and track consistently, so we're accurate, but the precision is not very great. We're doing some analysis to figure out where we feel we can safely determine trajectories etc...
Have fun!
-Terry
With a blob size of 1 pixel was there any decrease in the tracking reliability? If you move the camera (or the target) would it reliably stay locked on? I only ask because I'm interested to find out how small a blob the camera will track. Its great that you all have been able to make it work out of the box and is really due to Kevin Watson's hard work.
Unread 17-01-2006, 13:54
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Depends on your noise filter settings, I think. If you totally disable the noise filter, then it may be locked on then, but you will run into other problems.
We may not be shooting from 50ft away, but the camera tracking that far away means we can run full speed at our goal from the other side of the field, and be ready to shoot before we are actually in range. Saves time
Unread 18-01-2006, 01:14
Terry Sherman's Avatar
Terry Sherman Terry Sherman is offline
Mentor -- Software
FRC #0093 (NEW Apple Corps.)
Terry Sherman is an unknown quantity at this point
Yes, Kevin put in a great deal of hard work and we're thankful for it. We took each measurement 6 times to verify repeatability. The first 3 were from a static state and the last the was us moving the camera to that position and having it track along the way, each time the same result was determined.
We are using Noise Filter 1.
-Terry
Unread 30-01-2006, 23:21
Jared Russell's Avatar
Taking a year (mostly) off
Looking to get a new lens eh?
Oh, and to the guy who thinks precision is overrated - our shooter made the goal CONSISTENTLY from ~50 ft the other night.
Granted, our exit velocity might be a bit high...
Unread 31-01-2006, 22:01
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: CMUcam Results!
I'm glad everyone is getting such good results. The one piece of data lacking from this thread is ambient light level. Our school recently upgraded to super-efficient (and super-bright) lights. With them on, we're tracking at 15 feet; with lights off, 30+. How bright will the arenas be?
Jon Mittelman
Team236
Unread 31-01-2006, 22:19
Re: CMUcam Results!
Fairly subdued lighting - we are talking about university gymnasiums for the most part. If you get it working in a room with normal light, it will work fine in the arena, probably better.
I'm surprised that you can only get 30ft with the lights off, though.
Unread 09-02-2006, 00:38
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
Re: CMUcam Results!
Our previous testing had resulted in a distance of about 20ft, because we had put a threshold of 10 pixels to track due to earlier interference. We have now tuned the parameters and decided to try again.
We got a maximum distance of about 92ft today, in a fairly well lit hallway with the standard system. It would see 1 pixel, or 2-3 if placed on the floor (enlargement due to reflection). At this distance, the camera had a hard time tracking, but would re-lock on if it lost the light. In later testing with the light properly mounted on a goal, we saw about 6 pixels from a distance of 27 feet (half of the field).
FRC Volunteer, FLL regional planning committee member for Colorado
Former Programmer, Web Designer, Communications Director of Alpine Robotics Team 159.
Add your team to the FIRST Teams Google Map
Major CMUcam issues - LabView app won't work, very low-quality picture scottmso Programming 5 19-01-2006 17:51
Powering CMUcam without full-size RC? Mike Programming 3 17-01-2006 22:56
CMUcam for Dummies? nosaj4268 Programming 2 14-01-2006 23:55
CMUcam setup Ryan Collings Programming 26 13-01-2006 01:00
Screwed up results? TheFork 3D Animation and Competition 18 18-05-2002 15:47
