Go to Post Is there anything more inspiring than inspiration? The answer is no; there is not. - Jared Russell [more]
Unread 17-01-2006, 00:31
Jeffdewber's Avatar
Jeffdewber Jeffdewber is offline
Mentor Now!
FRC #0888 (Robotiators)
Jeffdewber is on a distinguished road
pic: 888 Ball Shooter Prototype
CraigHickman
Posts: n/a
Re: pic: 888 Ball Shooter Prototype
Looks cool.
How much range/accuracy do you get out of it?
Unread 17-01-2006, 00:42
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
have you tested this yet? and does the current configuration put spin on the ball that either helps or hurts your shot?? cool setup btw....
Unread 17-01-2006, 01:12
Jeffdewber's Avatar
Mentor Now!
Have not seen it work yet have been busy and out of the shop. But it is working and according to everyone it is pretty fast. They will update tommorow.
-Jeffrey Dewberry
Unread 17-01-2006, 01:23
cleonavicius cleonavicius is offline
AKA: Chris Leonavicius
FRC #0888
cleonavicius is an unknown quantity at this point
First off, thanks.
What you can't see is the mini-bike motor that drives it on the other side.
In its current configuration, it shoots about 30 feet, when elevated to a 30 degree angle.
According to a radar gun, it travels at 24-26 mph, just a bit more than 12 m/s.
Accuracy is decent, the person catching it at 30' usually doesnt have to move to catch it. This should increase with an automatic feed.
I'm not sure if it puts a spin on the ball, its been too much fun just seeing it work, however, im sure i can test it out more tomorrow
Unread 17-01-2006, 01:43
Looks cool. Are you using a belt to drive the shaft, or chains, or ??? Thanks!
Unread 17-01-2006, 02:08
FRC #0888
We tied the shaft directly to the motor.
Its a piece of 5/8" shaft with a 5/16" hole in one end and two set screws pressing on the flattened spot of the CIM's shaft.
Unread 17-01-2006, 02:19
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Always remember, the "it's just a prototype" attitude should never apply to electrical stuff. Sticking the wire leads off the CIM directly into the Anderson terminal of a battery to test your ideas is a baaaaaddddd idea.
At the very least, put a fuse block in line - or - more preferable, put in a Victor. If you plug the Victor into the motor port of a Vex Controller, you can control it very easily for prototyping and without any need for programming. In the picture below, our team was able to successfully control the CIM motor using the Vex controller.
Art Dutra IV
世上无难事,只怕有心人.
Unread 17-01-2006, 02:33
Jeffdewber's Avatar
Mentor Now!
Don't worry sir. We have been doing this for years with no problems and there our safe guards in place. We have not fryed a motor yet.
Unread 17-01-2006, 03:00
i_am_Doug i_am_Doug is offline
Currently foraging for food..
AKA: Doug
i_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura about
Send a message via AIM to i_am_Doug Send a message via MSN to i_am_Doug Send a message via Yahoo to i_am_Doug
Nicely done. I really like both signs in the back to.
Unread 17-01-2006, 10:55
Jeffdewber's Avatar
Mentor Now!
Yeah the no dumping sign is in our electronics work room. We put that there because people would always dump stuff in there. LoL
Unread 17-01-2006, 23:06
coldabert's Avatar
coldabert coldabert is offline
The Dude
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
First off, thats not "our" electronics room. That is my personal office that I have been renting out to Team 888. (I'm still looking for a secretary. I'm looking for anyone who can write poems, fill waterbottles, make runs to RoFo, and keep my radios charged)
And we have a test board set up with a dpdt switch, breaker panel, battery connectors, and a battery mount that we use to test our prototypes. I would recommend that all teams with similar materials should build one of these boards as they make testing very easy. I can post the schematic if anyone wants it.
One of the things we found with this design is that it is important to have that metal sheet tangent to the wheel to provide the maximum friction.
Unread 20-01-2006, 13:23
thesse thesse is offline
Freelancer
FRC #0888
thesse can only hope to improve
Send a message via AIM to thesse
I built the shooter and can say that it puts backspin on the ball which keeps it aloft longer.
-Theo
Unread 20-01-2006, 13:38
K.Shaw's Avatar
K.Shaw K.Shaw is offline
The Zoomin' Human
AKA: Shaw 1, kevshaw, little shaw
FRC #0237 (Sie-H²O-Bots (See-Ho-Bots), FLL #3954 (Swift Eagles))
K.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant future
Send a message via ICQ to K.Shaw Send a message via AIM to K.Shaw Send a message via MSN to K.Shaw Send a message via Yahoo to K.Shaw
doesn't it take the motor a little longer to speed up a wheel that size to max speed? once up to speed does the wheel slow down at all after a ball has been dropped in? are you able to shoot more than one ball a second and have them go the same height distance and land in about the same area? just a few things we ran into in our prototyping stages with a similar set up.
2005 Bash @ the Beach Winners -Thanks Team 1511 and Team 181
2005 NJ Regional Finalist -Thanks again to 56 and 303
2005 Radioshack Innovative Control Award-NJ
2005 FLR Semi-Finalists
2005 Radioshack Innovative Control Award-FLR
2004 Archimedes Divisional Semifinalists
2004 NJ Regional Winners. -Thanks Team 56 and Team 303!
2004 NJ G.M. Industrial Design Award Winner
2004 UTC Motorola Quality Award Winner
Unread 20-01-2006, 14:32
Andy B's Avatar
Andy B Andy B is offline
College Student, Mentor
FRC #1259 (Paradigm Shift)
Andy B will become famous soon enough
Send a message via AIM to Andy B
Very cool prototype.
One Quick Question though,
How did you mount the Large CIM Motot?
Thanks,
Andy B: College Student, Mentor
Paradigm Shift, 1259 http://www.team1259.org
2004 Midwest Regional: Team Spirit Award Winner, Highest Seeded Rookie Team Award Winner, 4th Seed, 7-1-0 Record , Lost in Quarter Finals
2005 Midwest Regional: Imagery Award Winners, 16th Seed, 5-5-0 Record, Unpicked
2005 Championships, Newton Division: 5th seed, 6-1-0 Record, Advanced to semifinals
2006 Wisconsin Regional: Judges Award, 23th seed, 5-7-0 Record, Unpicked
2007 Wisconsin Regional: 33rd seed, 3-4-1 Record, Lost in Quarterfinals
Team 358 Shooter Prototype Xero0ne Robot Showcase 14 20-01-2006 21:03
pic: cvt prototype CD47-Bot Robot Showcase 5 29-01-2004 01:10
pic: Swerve^2 Prototype CD47-Bot Robot Showcase 24 23-01-2004 12:11
pic: Team 857 Prototype Killough 2002 CD47-Bot Extra Discussion 19 13-10-2003 08:12
pic: Team 888 14" CD47-Bot Extra Discussion 2 16-03-2003 17:44
