Go to Post I know the world needs more engineers, but FIRST isn't all about engineers and robots... that's why it's so great. - Ryan Dognaux [more]
Unread 17-01-2006, 13:54
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Re: CMUcam test rules...
Originally Posted by seanwitte
With a blob size of 1 pixel was there any decrease in the tracking reliability? If you move the camera (or the target) would it reliably stay locked on? I only ask because I'm interested to find out how small a blob the camera will track. Its great that you all have been able to make it work out of the box and is really due to Kevin Watson's hard work.
Depends on your noise filter settings, I think. If you totally disable the noise filter, then it may be locked on then, but you will run into other problems.
We may not be shooting from 50ft away, but the camera tracking that far away means we can run full speed at our goal from the other side of the field, and be ready to shoot before we are actually in range. Saves time
Unread 18-01-2006, 01:14
Terry Sherman's Avatar
Terry Sherman Terry Sherman is offline
Mentor -- Software
FRC #0093 (NEW Apple Corps.)
Terry Sherman is an unknown quantity at this point
Yes, Kevin put in a great deal of hard work and we're thankful for it. We took each measurement 6 times to verify repeatability. The first 3 were from a static state and the last the was us moving the camera to that position and having it track along the way, each time the same result was determined.
We are using Noise Filter 1.
-Terry
Major CMUcam issues - LabView app won't work, very low-quality picture scottmso Programming 5 19-01-2006 17:51
Powering CMUcam without full-size RC? Mike Programming 3 17-01-2006 22:56
CMUcam for Dummies? nosaj4268 Programming 2 14-01-2006 23:55
CMUcam setup Ryan Collings Programming 26 13-01-2006 01:00
Screwed up results? TheFork 3D Animation and Competition 18 18-05-2002 15:47
