Go to Post I think it will be very hard to find one aspect of FIRST which doesn't inspire us. - Arefin Bari [more]
Unread 17-01-2006, 00:21
binary_sandman's Avatar
binary_sandman binary_sandman is offline
AKA: andrew sweet
FRC #1388 (Eagle robotics)
binary_sandman is infamous around these parts
has anyone made a custom com-1 output?
[color=Green]our programing team has made a wonderful custom com-1 output and has a problem with establishing a connection and wondered if any other teams had this problem.The program via hex file has a problem sharing with the custom com-1 output their we have to run one at a time. when we have the custom com-1 open the the controller dose not Respond to drivers vies versa.
we think it has to do with program Identification with robot code.
Unread 17-01-2006, 02:27
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Re: has anyone made a custom com-1 output?
Sounds like your custom program is opening the com port and keeping it open or busy while the IFI loader is trying to open the port. Your programmers should be able to fix this by having their custom program close the port before the IFI loader attempts to use it. As most programs will not try to use the serial port if it is already in use by another program.
Also you may want to be more descriptive in your posts, by telling us that you have a custom com-1 output this could mean hardware or software, and what it does we don't know you are more likely to get responses and help if the person reading your post doesn't have to guess at what you meant or what is going on. Also com-1 is the designation that windows uses for the first logical serial port. Also spell check is a feature that you should always use before you submit your post. Welcome to the CD community and we love to help others and share information, just try to be a bit more descriptive about things in your posts
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 17-01-2006, 10:29
Umm Errr...
Windows allows access to serial port by only one program at a time. If one program already has it open, additional connection attempts will fail. To my knowledge, there is nothing you can do about this other than have one of the programs close the port before the other tries to open it.
As a side note, if your program crashes with the serial port open, there is no way to close it and make it available again other than restarting the computer. This is true in windows 2000. I assume it is true in other version as well. I share this because it caused me a day of frusteration thinking there was something wrong with my program.
1139 Alumni
Unread 17-01-2006, 10:46
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
I'll try to translate this...
Our programming team has made a custom program that attaches to COM1, but it can't establish a connection. Have any other teams had this problem? The program that downloads the hex file has a problem sharing the connection with our program, it only lets us run one successfully at a time. When we use our custom program, the RC will not respond to drivers commands via the OI. We think it has to do with the robot identifying the program.
Spelling and grammar are your friends. Thanks Dave =)
So from what I understand, you made some kind of a system to communicate with your robot. What is this program trying to do? The only data you can get from the RC is the hex file... not much use having that.
Assuming your using the programming port to send data and you are using this program to grab that information... there's no need for a custom program. All you need is a terminal program. I recommend Bray's Terminal, it's simple and it works. If you can't download anything onto the laptop, Windows comes with a terminal. It's called HyperTerminal and can be accessed by going to Start > Run and typing in hypertrm. However, if you do use this, be aware that it is a Windoze program and most likely won't work as expected.
Your interference problem will still consist with another terminal. You can't have two programs accessing one RS232 port... the one that got there first will lock all others out.
-Mike
http://www.mikesorrenti.com/
Unread 17-01-2006, 10:51
Restarting the computer to release a port is not always necessary. It's usually sufficient just to log off and back on again.
Unread 17-01-2006, 10:54
Mike's Avatar
AKA: Mike Sorrenti
Couldn't you also go into Device Manager and Disable/Enable the port?
I've never had this kinda problem happen to me, but I assume that would work.
Unread 17-01-2006, 14:24
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
You can also get a utility from www.sysinternals.com to monitor and close the ports I believe, don't recall the name but take a look around it can't be too hard to find.
Matt Krass
Unread 17-01-2006, 14:49
Mike's Avatar
AKA: Mike Sorrenti
http://www.sysinternals.com/utilities/portmon.html
Portmon
Unread 17-01-2006, 16:05
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
When I killed the cygwin version of picloader, it freed the serial port. (Windows XP.) Could be driver-specific, or a fixed bug.
Encoder Output Problems Mike Electrical 5 25-11-2005 21:43
Custom Made Shoes sanddrag Chit-Chat 0 03-11-2005 02:03
EasyC v. 2.0 - New features, custom user functions, and more! artdutra04 FIRST Tech Challenge 1 02-11-2005 13:36
FIRST made slashdot... cool Brandon Martus General Forum 4 08-01-2002 01:12
