Low Cost Planetary Gearbox Source...
While looking for some gearboxes for Robotic Amusements on ebay, I came accross the company BaneBots.
As it turns out, they make some pretty nice transmissions. AND they make some that are that the Fisher-Price and the Mabuchi motors will (pretty much) just bolt to (buy a gear or pull of the one that is on the stock motor, press the pinion on the FIRST legal motor, reassemble the gearbox, and mount it on your robot). They come in a variety of ratios (5:1, 16:1, 20:1, 25:1, 64:1, 100:1, 256:1). The gearboxes have nice mounting points and beautiful 3/8" Dia output shaft that is long, easy to access (and support) and keyed w/.125 key. ![]() I have 2 of these jewels on my desk right next to me. Here is my thoughts. They are sweet! But you are going to have to take the good with the bad. The good:
Good Luck, Joe J. Disclaimers:
Re: Low Cost Planetary Gearbox Source...
Larry Barello asked this question Here
To answer your question, Larry, this is the exact motor/gearbox you want. You also have to buy this pinion or pull the one of the motor that the gearbox comes with. Good Luck, Joe J. |
I talked to Rick Marriot from Bane Bots today and he said the If you order on the internet he can usually ship in about 2 days based on stock avaliabilty.
These are nice gearboxes. (no plastic gears). Has anyone figured out if the speed controllers are also legal FIRST parts? |
Joe J. |
Free speed = 3120 RPM, Free current = 0.9 Ampere, Stall torque = 192 oz-in, Stall current = 37 Ampere There is a disclaimer saying these are calculated values and they do not factor in loss from the gearbox. Using my lab equipment (ISO calibrated stuff: Magtrol HD-715 brake and Sorenson DCS 20-150 power supply) I measured: Unloaded speed = 3093 RPM, Unloaded current = 2.4 Ampere (note that my dyno drag at this speed is about 1.2 oz-in, due to friction, coupling flex, and un-energized brake drag) When I increased the load to draw 5.0 Ampere, the speed was 2780 RPM and the indicated torque was 16.7 oz-in When I further increased the load to draw 10.0 Ampere, the speed was 2070 RPM and the indicated torque was 39.3 oz-in When I further increased the load to draw 15.0 Ampere, the speed was 1350 RPM and the indicated torque was 60.7 oz-in When I further increased the load to draw 20.0 Ampere, the speed dropped below 500 RPM and the brushgear started to smoke, so I quickly de-energized the brake to minimize damage. All the while the little gearbox was rattling and whining, I'd estimate about 100 dB at 1 meter. I would not recommend this unit for extended continuous duty! It's acoustic signature is annoying and losses in the gearbox are clearly significant. However as you point out it may be quite useful for mechanisms with intermittent duty and low endurance requirements. And the price is certainly right. So my conclusion is that the gearboxes are at best about 80% efficient, and this drops to about 60% at heavy loads. I would not want to take them to more than about 10 Amperes motor draw for longer than a minute or so. |
As to the conclusions, I am not sure I entirely concur. In particular, much of what you recommend involves the particular motor the gearbox comes shipped with (which is not a legal FIRST motor). Even so, plotting the data, they don't seem pretty non-linear to me. Any non-linearity seems easily explained by the motor heating up as you increased the load. The FP motors are prone to heat build up. It is extremely easy to pound more heat into that little package than can be safely passed off to the surrounding air. The same can be said for the motor that the Banebots transmission ships with. This is well documented elsewhere in other threads, but think about this: A curling iron is typically a 20Watt device. Think of how hot a curling iron gets and it is only dissipating 20W. At 15Amps & 12V, the test above was inputting 180W of electrical power (V*I) to the motor. Of that, only 60W as being converted to Mechanical Power (T*w), leaving 120W to heat up the curling iron, I mean, Motor. Back to my comments on the data, I think that the data on effeciency is somewhat affected by the heating of the motor. If I assume that the motor data is correct (even when the motor was hot), I get 72%, 80%, 61% and 56% at Freespeed, 5Amp, 10Amp, & 15Amp data points. I am not sure how to intrepret this data. My experience say that 5:1 planetary gearboxes should be about 80-90% eff. per stage (we have only 1 stage in this case). One way of looking at it is to say that the first data point is off due to drag, etc, and that the last two reflect that the motor was getting hot. But, I could be trying to fit the data to my view of the world, so I don't know what to say. Based on the data, I would perhaps estimate the gearboxes to be say 70% per stage and (using given that relatively low effeciency) I would try to keep the 12V load point of the FP to below 1/4 of the 12V stall (i.e. keep the motor spinning above 75% of its free speed). My experience with the FP is that if you do this, they'll be able to survive a FIRST season. My final comment is that the data generally support that these gearboxes are not jewelry. They are cheap and dirty. But... ...I would just say that the price and effort are right... ...for the right application. Joe J. Last edited by Joe Johnson : 17-01-2006 at 16:59. |
#7
In any case, I still would not recommend this gearbox for continuous running above 10 Ampere load. And I still think the noise it makes is annoying. My team plans to try launching balls using two of these gearboxes, fitted with kit FP motors and 6" wheels. For that kind of loading I would expect them to last through a FIRST season. |
#8
Thanks for the find, these are very attractive.
As an aside, has anyone opened one of these things up? How are they lubricated? Any opinion of the quality of construction and possible durability issues? Perhaps a little bit more or better lube could help with the noise? -Andy A. |
#9
The only way go to get lousy gears to even RUN in a planetary gearbox is to increase the backlash -- ALOT! Add to this that there are only 3 planets per stage and that (with the exception of the final stage) the centerline of the carrier (and that means the sun) is determined by the planets... what do you get??? ...well.. ...This: ![]() ![]() ![]() Joe J. |
#10
This is not true. The FP motors CAN take continuous use. They CANNOT operate near 12V stall or even at 70% of 12V stall (a.k.a. below 30% of their 12V free speed when applying 12V to the motor) for long periods of time without turning into a stinky, smokey blob of copper. You do not give enough information to know if the conditions you are talking about are reasonable. At 12V, the FP motor puts out .4 N-m at stall. With 2 stages of 4:1 each @ 70% eff. you will get Tgearbox stall = .4 X 4 X 4 X .7 X.7 = 3.1N-m. I recommend that you operate at about 1/4 of this number to run continuous and happy all season long (not that you can't muscle through more than that for a short time - a few seconds say - but that you should not need more than this for 10s of seconds at a time). Can you keep the continous torque on each motor to below .75N-m? Let's assume that you have 4" pulleys on your <secrect mechanism> This works out to a radius of about 50mm = .05m. That means that you could get 15N (3.4lbs) on the <secrect mechanism> continuously. Is that enough? It is hard to know without my getting into the nickers of your <secrect mechanism> design. By the way, the <secrect mechanism> would be FLYING at almost 4 m/s (12ft/sec)* when driven by a 4" pulley with a tangential load of 15N. If you don't need a <secrect mechanism> that is so fast, use a smaller pulley or a higher gear ratio gearbox. Joe J. *I made a mistake in my calc. my initial posting mistakenly claimed 25m/s which was just whacked. Sorry. Even so, 4m/s is not exactly turtle speed. Here is my calculation for review and perhaps further corrections: 16000 RPM @75% (i.e. 1/4 stall torque) = 12,000 RPM (@ motor) Last edited by Joe Johnson : 17-01-2006 at 21:21. |
#11
My recommendation above was just to avoid continuously loading the BaneBots gearmotor at currents greater than about 10 Ampere (about 25% of its 12V stall current). I really don't like to see smoke coming from motors, and this one started smoking at 20 Ampere. Last edited by Richard Wallace : 17-01-2006 at 22:04. |
#12
Joe J. |
#13
How do these transmissions compare with the DeWalt XRPs: efficiency, value, reliability, power transmission, etc?
Tnx ... jon |
#14
They are quick and easy. They are smaller and cheaper than the XRP transmissions. That is their main advantage. As to the right value, it depends on the application. For the right application, I think they provide a fantastic value proposition. For tougher applications (for example an application that involves impact loads or high torque), I would use modified Dewalts. Joe J. |
#15
| TTL port to a serial port on a demo board | ImmortalAres | Programming | 16 | 09-07-2005 23:44 |
| **FIRST EMAIL**/Important Fisher-Price motor and gearbox information | sanddrag | FIRST E-Mail Blast Archive | 1 | 11-02-2005 18:19 |
| [FVG]: Source Code | SilverStar | FIRST-related Organizations | 5 | 24-08-2004 14:28 |
| Low Cost Field BOM | Andy Brockway | General Forum | 161 | 11-01-2004 08:34 |
