Go to Post Quitting when faced with adversity is not the answer. We have to figure out a solution within the constrainsts applied. - Rob [more]
Unread 17-01-2006, 17:16
sheyna's Avatar
sheyna sheyna is offline
FRC #1748 (Lab Rats)
sheyna is an unknown quantity at this point
Servos not getting right voltage
ok my cmucam takes picture perfectly but my servos dont move. we tested the pulse width modulation on our oscilloscope and it is giving out the right pulses and the batter is giving out 7.5 but we test the pins where the servos connect and it is giving out only 1.5. what do you think the problem is?
~sheyna
Unread 17-01-2006, 17:55
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Re: Servos not getting right voltage
Are your servos connected to the camera or the robot controller?
Unread 17-01-2006, 21:57
If the servos are plugged directly into the camera, make sure the "servo power" jumper is connected properly.
Standard Servos? Matt Krass FIRST Tech Challenge 4 22-11-2005 08:09
DC Voltage indicator Don Wright General Forum 5 09-09-2005 07:52
Voltage on Frame Greg Electrical 31 02-03-2004 13:49
RC Circuits Melissa Nute Math and Science 3 25-01-2004 05:02
Output voltage in PBASIC diego25 Programming 7 31-01-2002 22:50
