Go to Post will.i.am should be evangelizing FIRST, not vise-versa. - basicxman [more]
Unread 17-01-2006, 17:10
Excelsior's Avatar
Excelsior Excelsior is offline
Electrical Head
AKA: Alex Hughes
None #1208 (Metool Brigade)
Team Role: Electrical
Excelsior is on a distinguished road
Send a message via AIM to Excelsior
What size breaker should I use for the RC?
Heh, silly question, but important, I'd think.
Team 1208
The Metool Brigade
Three Hours Short of Going Insane
0=====<(' '<) <( ' ' )> (>' ')>=====0
Unread 17-01-2006, 17:15
Sscamatt's Avatar
Sscamatt Sscamatt is offline
AKA: Matt Syska
FRC #0195 (Cyber Knights)
Sscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud of
Send a message via AIM to Sscamatt
Re: What size breaker should I use for the RC?
<R89> You must protect the Robot Controller power feed with a 20A Circuit Breaker. You may not connect any
other electrical load to this breaker.
Be sure to read through the entire Manual before you wire. There are a lot of things that have to be done a specific way.
2006 Championship Finalist, Thanks 25 + 968!
2006 Newton Division Winner
2006 International Innovation In Control Award
2006 Radio Shack Innovation in Control Award, UTC Regional
RIT Class of 2011
Excelsior's Avatar
Electrical Head
AKA: Alex Hughes
Thankee much.
Team 1208
The Metool Brigade
Unread 17-01-2006, 17:19
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
in the ROBOT section of the manual, 5.3.9.1 Circuit Breaker / Fusing Rules
there is a small picture next to rule <R90> and <R91> and shows you that it requires a 20amp fuse
-Osc
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 18-01-2006, 07:34
Alex,
If you are using the supplied fuse blocks instead of the IFI block, I recommend that the first position (closest to the power stud) be used for the RC power. Any voltage drop in the fuse block is then minimized for the RC.
New Model Posted - 2005 Breaker Panel Ed Sparks Inventor 5 01-01-2006 23:25
breaker rules Joe Ross Electrical 4 14-01-2005 22:50
Keyang Motor Thermal breaker. archiver 2000 1 24-06-2002 00:24
60 amp breaker Anne Lam Technical Discussion 10 10-01-2002 15:13
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
