Go to Post the few, the proud, the animators. - BuddyB309 [more]
Unread 17-01-2006, 16:53
Zoom's Avatar
Zoom Zoom is offline
Lost User
AKA: Umair Nasir
FRC #0369 (Nuts & Volts)
Zoom is an unknown quantity at this point
Send a message via MSN to Zoom
CmuCam problem
Our cmucam does not track the target. We got the code from kevin's site. download it to the rc. did everything. I searched before posting but couldnt find any answers. cam just stays there. The lights are green. what could be the problem?
A Program isnt finished until the Programmer dies...
Unread 17-01-2006, 17:28
Re: CmuCam problem
  • Servos are hooked up to pwm01 & 02?
  • Camera power is connected by PWM cable to an empty RC PWM output?
  • PWM cable is attached to the camera serial port and the RC via TTL converter?
  • Backup battery is connected to the RC and fully charged?
  • 12v battery is hooked up to the RC and fully charged?
  • OI is tethered or linked by radio to the RC and powered?
  • Green power LED on the camera power is on?
Can you call up Kevin's tracking and camera menus?
Did you test separately with Labview?
Unread 17-01-2006, 17:32
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Re: CmuCam problem
We are having the exact same problem and we can access the camera and tracking menus but the terminal window never display's searching. We have a red and green light lit up on our camera.
Unread 17-01-2006, 19:11
Zoom's Avatar
Lost User
AKA: Umair Nasir
Re: CmuCam problem
when you say pwm 1,2. do you mean the robot controller. if yes. then yes the pwm are in 1 and 2. the power is also good. we checked in labview. it works fine there. but when we use the robot. it does not work. After uploading the code to rc nothing happens in the terminal window.
Can you call up Kevin's tracking and camera menus? sorry, dont what you mean. maybe this is the part im lost at.
Unread 17-01-2006, 19:16
FRC #0935
Re: CmuCam problem
To get the tracking menu you type "t" at the bottom of the terminal window.
To get the camera menu you type "c" at the bottom of the terminal window.
You'll probably have to reset the robot after you download the code. If you get no response in the terminal window try resetting the robot.
Unread 17-01-2006, 19:18
mallot1243's Avatar
mallot1243 mallot1243 is offline
FRC #1243
mallot1243 is an unknown quantity at this point
Re: CmuCam problem
I'm assuming that you chose the pwm01 and 02 on the rc and not the jumpers on the camera itself. Also, the default code from Kevin's files are too large to fit in the EduBot Controller, is there a special file for using on the Edu or do I have to commit a hack job on the code to lighten it?
And whoever came up with the idea of only writing the LabView program for Windows 2001 SP1 or higher?
Unread 17-01-2006, 19:36
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: CmuCam problem
The code was developed on a EDU-RC. What makes you think it won't fit?
-Kevin
Kevin Watson
http://kevin.org
Unread 17-01-2006, 19:38
mallot1243's Avatar
FRC #1243
Re: CmuCam problem
My compiled version with other small tidbits of code was nearly 500Kb, when I exported it I used 0x800, would I have to change this?
Unread 17-01-2006, 19:43
FRC #2429
Re: CmuCam problem
It it doesn't fit, the linker will tell you so. Look at the .map file, which will tell you how much memory (flash & SRAM) you've used.
-Kevin
Kevin Watson
http://kevin.org
Unread 17-01-2006, 22:01
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Re: CmuCam problem
Windows 2001 SP1?
What?
-Joe
Unread 18-01-2006, 05:55
or yaniv or yaniv is offline
or yaniv is an unknown quantity at this point
Re: CmuCam problem
I have the same problem
Originally Posted by Mark McLeod
  • Servos are hooked up to pwm01 & 02? yes
  • Camera power is connected by PWM cable to an empty RC PWM output?yes
  • PWM cable is attached to the camera serial port and the RC via TTL converter?yes
  • Backup battery is connected to the RC and fully charged?yes
  • 12v battery is hooked up to the RC and fully charged?yes
  • OI is tethered or linked by radio to the RC and powered?yes
  • Green power LED on the camera power is on?yes
Can you call up Kevin's tracking and camera menus?yes
Did you test separately with Labview?yes
Or
Unread 18-01-2006, 11:27
FRC #2429
Re: CmuCam problem
Originally Posted by or yaniv
I have the same problem...
Download the code mentioned here and report back with the results. This thread may also help. Someone pointed out that they had a defective PWM cable. You might replace the PWM cable you're using for serial communications and see if it starts working.
-Kevin
Kevin Watson
http://kevin.org
Unread 18-01-2006, 23:33
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: CmuCam problem
hmm...
ok you are having the smae problem we did.
you have to calibrate your camera, because there is too much noise in your background that is affecting your stats.
the calibration manual (Here) Contains the information you need to calibrate.
also, make sure that you dont have the wrong axes flipped (read the cam manual if you dont know what i maen)
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 19-01-2006, 15:19
Zoom's Avatar
Lost User
AKA: Umair Nasir
Re: CmuCam problem
Servos are hooked up to pwm01 & 02? YES
Camera power is connected by PWM cable to an empty RC PWM output? YES
PWM cable is attached to the camera serial port and the RC via TTL converter? YES
Backup battery is connected to the RC and fully charged? YES
12v battery is hooked up to the RC and fully charged? YES
OI is tethered or linked by radio to the RC and powered?YES
Green power LED on the camera power is on? YES
Can you call up Kevin's tracking and camera menus? YES
Did you test separately with Labview?YES
everything is fine. But the servos dont move. even if you try to move them through the menu.
Unread 19-01-2006, 15:31
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: CmuCam problem
This is just a shot in the dark. By any wild chance, are the lines in user_routines.c/Default_Routine that assign the joystick inputs to the PWM outputs not commented out?
If they are uncommented, then they are being processed after the camera code, and therefore, are overwriting the values set by the camera code.
During testing they should look like this.
//pwm01=p1_y;
//pwm02=p2_y;
or this
/*pwm01=p1_y;
  pwm02=p2_y;*/
Kevin's code, without any modifications, doesn't actually call the Default_Routine function. It is commented out in the Process_Data_From_Master_uP function. Therefore, the PWM mappings never get called. If your version of user_routines.c is not from his camera code build, that may be what is happening.
Labview CMUcam demo problem Windward LabView and Data Acquisition 19 11-08-2007 02:33
CMUcam setup Ryan Collings Programming 26 13-01-2006 01:00
Need a realistic Statics Problem sanddrag Technical Discussion 10 05-12-2005 15:07
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
