Go to Post Gracious Professionalism does not take a holiday. - JaneYoung [more]
Unread 17-01-2006, 21:06
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Light fades out?
This isn't specifically about the CMUcam, but about the green light.
We have ours made, and I connect it to a Radioshack Adaptaplug AC Adapter. It puts out 12vdc and 1 amp. When I connect it to the light, the light is bright for about 40 seconds and then starts to fade out. Eventually it gets so low that it might as well be off. If I disconnect the power wires and re-connect, it works fine again and the cycle repeats.
Any idea on what could be causing this?
EDIT: A quick multimeter check shows that my power supply is holding a constant voltage when not connected to the light.
http://www.mikesorrenti.com/
Unread 17-01-2006, 21:26
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Light fades out?
This same exact thing happened to us, though it lasted a lot longer than 40 seconds, maybe 5 or ten minutes. We had an enclosed box, with holes but no fans, and when we opened the box, afraid we'd killed our transformers, it had just gotten warm enough that the adhesive label on the transformers was peeling off. We redid the box, increasing it's size and adding a big fan. The problem went away; in fact, I believe that we have run it for like 6 hours straight. We are using a 12 volt, 1.5 amp power supply.
-Sir Francis Bacon
-Albert Einstein
Unread 17-01-2006, 21:33
Mike's Avatar
AKA: Mike Sorrenti
At first I thought it was overheating as well. I just took off the cover and it still happened. The box is made out of steel and we have that small (1 inch diameter?) muffin fan mounted in it.
Unread 17-01-2006, 21:35
FRC #0306 (CRT)
I don't know. We also took off the cover, and the same thing happened again, albeit to a lesser degree. If you could, try using the large (3"?) fans, sucking air out. Don't know. When we did this, it seemed to fix the problem.
Maybe they draw more current as they heat up?
-Sir Francis Bacon
-Albert Einstein
Unread 17-01-2006, 21:37
Mike's Avatar
AKA: Mike Sorrenti
I think that may be it... I remember a post comparing the amp pulled at cold and after X minutes. I'll search for it. Thanks for tipping me off
Unread 17-01-2006, 21:41
FRC #0306 (CRT)
Yeah, somewhere, somebody said they used a 1 amp power supply, and it didn't cut it. Though they said that it ended up putting out 8 volts, dimming the lights, but not cutting them out. I'd definently try a bigger power supply. Maybe just rig a battery in to check for right now.
-Sir Francis Bacon
-Albert Einstein
Unread 17-01-2006, 21:56
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
The piece of paper that came with each lights says that each transformer should be on a 2amp fuse. We are powering outs with a robot battery and 5amp fuse, and haven't had any problems with it. It doesn't drain the robot a lot, so one basically lasts all day.
Unread 17-01-2006, 22:14
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Ive used a computer power source and have had no trouble either. I'm curious when they fade out is part of the tube being lit and not the other? Like light is only near the wires? Or is the whole thing dimming and turning off?
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 17-01-2006, 22:17
Mike's Avatar
AKA: Mike Sorrenti
The whole thing is dimming.
I'm going to get a robot battery tomorrow, I'll post how it goes.
Unread 17-01-2006, 22:35
I thought the light box was closer to a 2.5 amp load. Your power supply is probably overheating and shutting down.
Unread 17-01-2006, 22:36
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Have you tried useing the backup battery. The 7.2 volts it has is enough to have 4 completely on and 4 sort of on. Try that and see if it works.
Unread 17-01-2006, 22:39
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
That was me. We've since moved to hooking our light directly into a 12v robot battery, and that seems to work great. We really haven't left it powered on for more than a few minutes though, so I can't be of any help there.
Unread 17-01-2006, 22:51
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
We're using a 12VDC, 1.5A transformer and it seems to be alright. When connected, the voltage is ~11.2V, so the transformer is slightly overloaded, but probably alright. It gets a little warmer than I'd like, but again, it seems to be fine. I should also note that we are only using 7 lights. One of the supplied lights was bad.
As for a box, we didn't use one. I just put together a quick and dirty setup. I just duct taped the lights and inverters to the provided plastic sheet. It does get warm after a few minutes, so if it were in a box, I might be concerned about it.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 17-01-2006, 23:13
I can't stress enough how useful a rigged computer power supply can be. I ran 7 converters off one of them with no trouble. Of coarse I also can't stress enough how important it is to do it safely (ie check that you have the right cable and you have a sufficient load). You can virtually (I wouldn't try the motors) test your entire electrical system on one. note I make no claim that doing this is not without risk and if you do do it I don't guarantee that you won't fry some electronics. I never have, but it can happen. Here's a thread on how to rig one http://www.chiefdelphi.com/forums/sh...ad.php?t=39754
How many users does it take to change a Light Bulb? Matt Attallah Chit-Chat 4 04-09-2004 20:59
Please...no more steenkin' light! Andrew General Forum 37 17-04-2003 23:06
light visibility Erinn888 General Forum 30 17-02-2003 15:56
Important info about light Jay Lundy Technical Discussion 10 12-04-2002 11:37
How many posters does it take to change a lightbulb? Brandon Martus Chit-Chat 7 22-02-2002 19:48
