Go to Post FRC is a game of mentors. The best teams are guided by mentors who know how to balance on the knife edge of pushing the envelope and achieving success. - Mr. Van [more]
Unread 17-01-2006, 21:47
Umm Errr...
RS232 Radio link
Has anybody ever tried using a 3rd party radio modem attached to the program port for uploading code and debugging?
how about rs232->802.11 converters? I have used rs232->ethernet converters on automation projects before. surely someone makes a wifi version. I suppose i could always tie an rs232->ethernet converter to a ethernet->wifi converter but thats bulky. If i went this route i would need to find software to take a TCP connection and make it look like a serial port in windows if i wanted to use IFI loader. It would be really cool to be able to access our robot wirelessly from any computer in our lab.
if rs232->802.11 is impracal then a pair of transparent radio modems would be great.
I'm hoping for a solution <$200.
BTW this is not for competition use, so don't bother telling me its not legal.
1139 Alumni
Unread 18-01-2006, 07:29
Re: RS232 Radio link
Jim,
It is my understanding that the radio uses a modified RS422 protocol, not RS232.
Unread 18-01-2006, 08:01
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
As to uploading code, life might be tricky. There are timing issues etc that I am not sure that most radio protocols would be able to meet.
As to just getting data back and forth from a printf statement, you can probably get away with many types of radios.
I like the Bluetooth radios by AirCables.net, but others have other favorites.
I seem to recall that Kevin Watson or Mike Betts recommending these radios once But, the remote radio is only TTL & only has Tx & Rx not all the RTS, CTS, etc. pins that a "real" RS-232 port has so I think replacing the programming cable is out of the question.
Good luck.
Joe J.
Team #88, TJ2
Unread 18-01-2006, 10:09
Umm Errr...
Yea, you are probably right. If USB converters cause issues, then radio odems would probably really cause issues. Uploading code would be nice, but i am mainly after remote debug via some custom programs we wrote. I know that the actualy UART on the pic doesn't understand any of the flow control pins and they arn't important under debug operation. I am wondering if these are being used to signal that the computer wants to upload code.
1139 Alumni
Unread 18-01-2006, 11:20
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
I haven't tried it, but you could try http://www.sparkfun.com/commerce/pro...roducts_id=582 , which includes the CTS/RTS lines. I don't think its as simple as plug-and-play, there's some config you have to do to tell the module what serial mode you will be using, and you would have to make an adapter cable to go from the header to a db-9 connector.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 18-01-2006, 11:31
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
The programming port does not require CTS/RTS lines. We built ourselves a long cable last year which contained ony TX, RX, and ground which worked fine.
Additionally, I purchased one of the BlueSMIRF modems from SparkFun last summer - they do not work to download code. As mentioned here already, I suspect this has to do with timing which is the same problem as seen with some USB converters. In an effort to correct this I wrote my own version of the IFI loader which I was in the process of tuning to address the timing dependencies, but that project got put on the back-burner as our team activities started up in the fall...
However, the BlueSMIRF does work nicely for debug output from the RC. You do have to reconfigure some of it's settings to allow it to keep up with the 115200 stream coming out of the programming port though.
Unread 18-01-2006, 11:37
While the enhanced BlueSMiRF lets you work without a serial cable, you will still have to physically press the "program" button on the RC, so you can't really program the robot from a distance. Even with the need to press the button, I think getting rid of the cable is likely to make things a lot more convenient.
If there were a wireless module which combined a full-featured high speed serial link and an additional pair of switches, though...that is something I might even pay for out of my own pocket.
Unread 18-01-2006, 11:55
Software Engineer
Rookie Year: 1995
One of the features I was going to attempt with my version of the IFI loader and the BlueSMIRF was to repurpose one of the CTS/RTS lines on the SMIRF to be used to "press" the program button (via the header that IFI provides). With custom loader software those lines can be easily manipulated independently.
Unread 18-01-2006, 12:02
Kevin Watson's Avatar
La Caņada High School
FRC #2429
As others have pointed out, the various SMiRFs won't allow you to program the 'bot remotely. They will, however, make debugging of a moving 'bot much easier. I've used a pair of SMiRFs to remotely tweak the camera software via the menus and it works well.
-Kevin
Kevin Watson
http://kevin.org
vex radio foobert FIRST Tech Challenge 1 05-11-2005 08:10
Exclusive IDE Download Link MrToast Programming 55 13-01-2005 09:46
half link chain link greencactus3 Technical Discussion 9 16-11-2004 13:31
vBCode to link to specific rules. Brandon Martus CD Forum Support 1 21-02-2004 21:03
