Go to Post Al Gore invented the internet...right? :p - coastertux [more]
Unread 17-01-2006, 21:56
Issues Issues is offline
FRC #0525
Issues is on a distinguished road
frc_camera not working but labview does
We can lock on and track the target with labview, but when we try to use kevin's code (frc_camera.zip)with the same configuration values it doesn't work properly. It continually searches for the target, and always returns a confidence value of 0. Here are the configuration values that we used.
#define AGC_DEFAULT 19 // Automatic Gain Control Register [0/0x00]
#define BLU_DEFAULT 128 // Blue Gain Control Register [128/0x80]
#define RED_DEFAULT 128 // Red Gain Control Register [128/0x80]
#define SAT_DEFAULT 128 // Saturation Control Register [128/0x80]
#define BRT_DEFAULT 2 // Brightness Control Register [128/0x80]
#define AEC_DEFAULT 3 // Automatic Exposure Control Register [127/0x7F]
#define COMA_DEFAULT 32 // Common Control A Register [36/0x24]
#define COMB_DEFAULT 32 // Common Control B Register [1/0x01]
#define COMI_DEFAULT 128 // Common Control I Register [0/0x00]
#define EHSH_DEFAULT 128 // Frame Rate Adjust Register 1 [0/0x00]
#define EHSL_DEFAULT 32 // Frame Rate Adjust Register 2 [0/0x00]
#define COMJ_DEFAULT 132
Any help would be appreciated.
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
National Instruments LabVIEW and Data Acquisition Forum Danny Diaz National Instruments LabVIEW and Data Acquisition 1 16-01-2006 13:20
COM port settings for CMUcam labview testing and programming pwilczynski Programming 1 15-01-2006 15:09
National Instruments LabVIEW & Data Aquisition Forums Brandon Martus Announcements 0 22-11-2005 21:12
I'm working :) Jack FIRST Scouting Network 2 03-01-2004 01:26
