Go to Post I mean who does want to write their code like this... [CODE] CANHAZ.VICTOR; GIMME.VICTOR; VROOMVROOM.VICTOR(1); KTHNXBAI; [CODE] - JohnFogarty [more]
Unread 17-01-2006, 21:56
Issues Issues is offline
FRC #0525
Issues is on a distinguished road
frc_camera not working but labview does
We can lock on and track the target with labview, but when we try to use kevin's code (frc_camera.zip)with the same configuration values it doesn't work properly. It continually searches for the target, and always returns a confidence value of 0. Here are the configuration values that we used.
#define AGC_DEFAULT 19 // Automatic Gain Control Register [0/0x00]
#define BLU_DEFAULT 128 // Blue Gain Control Register [128/0x80]
#define RED_DEFAULT 128 // Red Gain Control Register [128/0x80]
#define SAT_DEFAULT 128 // Saturation Control Register [128/0x80]
#define BRT_DEFAULT 2 // Brightness Control Register [128/0x80]
#define AEC_DEFAULT 3 // Automatic Exposure Control Register [127/0x7F]
#define COMA_DEFAULT 32 // Common Control A Register [36/0x24]
#define COMB_DEFAULT 32 // Common Control B Register [1/0x01]
#define COMI_DEFAULT 128 // Common Control I Register [0/0x00]
#define EHSH_DEFAULT 128 // Frame Rate Adjust Register 1 [0/0x00]
#define EHSL_DEFAULT 32 // Frame Rate Adjust Register 2 [0/0x00]
#define COMJ_DEFAULT 132
Any help would be appreciated.
Unread 18-01-2006, 12:42
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: frc_camera not working but labview does
Make sure the color spaces match. Kevin's code uses YCrCb. I don't know what LABView uses.
Unread 18-01-2006, 15:05
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
We had the exact same problem. Kevin's code DOES use the YCrCb colorspace. You can either recalibrate in that colorspace or change the camera's color space. In the frc_camera_s.zip program, the revelvant constant is in camera.h. Set COMA_DEFAULT to 40 to use RGB with no auto white balance.
Unread 18-01-2006, 15:17
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
We had a similar issue, and the culprit in our case was the servo motor speed
1. Camera would start the search sequence, looking for targer.
2. First pan sweep wouldn't see it. Camera swings back to the left to start second sweep.
3. While the camera is sweeping back, the camera sees the target, but since it is in the middle of sweeping back to start the next scan, it loses lock on it and has to restart scanning.
Making some minor tweaks to the target tracking code fixed this for us.
It also helps to make sure the camera is calibrated correctly.
Unread 18-01-2006, 18:31
FRC #0525
We have it calibrated in the right colorspace, but after further thought we think it is the direction the server tries to adjust itself when it is tracking that is backwards. Right when the red tracking light goes on, it moves away from the target. We tried flipping the jumpers, but since it is being controlled from the code we have to do it there... I was wondering if doing something like this would work...
in tracking.c
Change
pan_error = (int)T_Packet_Data.mx - (int)Tracking_Config_Data.Pan_Target_Pixel;
to
pan_error = (int)Tracking_Config_Data.Pan_Target_Pixel-(int)T_Packet_Data.mx ;
Unread 18-01-2006, 18:46
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
in tracking.c
Change
to
Sounds like you have the servos connected to the RC on PWMs 1&2. Good!
Now open tracking.h and read the comments between lines 60 and 65. (This is for the Bells and Whistles version). The same configurations are available in the simple version as well.
Unread 18-01-2006, 19:20
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
I think this solves the problem we were having today. Thanks! Oh and as far as calibration, it's best just to use the default numbers that come on kevin's code, trust me.
Unread 18-01-2006, 19:23
iBheat's Avatar
iBheat iBheat is offline
FRC #0418 (Lasa Robotics)
iBheat is on a distinguished road
// If your camera suddenly moves away from the target once
// it finds it, you'll need to change the sign on one or
// both of these values. Start with the tilt first.
#define PAN_ROTATION_SIGN_DEFAULT -1
#define TILT_ROTATION_SIGN_DEFAULT 1
That is the code in tracking.h!
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
National Instruments LabVIEW and Data Acquisition Forum Danny Diaz National Instruments LabVIEW and Data Acquisition 1 16-01-2006 13:20
COM port settings for CMUcam labview testing and programming pwilczynski Programming 1 15-01-2006 15:09
National Instruments LabVIEW & Data Aquisition Forums Brandon Martus Announcements 0 22-11-2005 21:12
I'm working :) Jack FIRST Scouting Network 2 03-01-2004 01:26
