Go to Post Deodorant cannot be stressed enough. To quote a teammate "body odor is a body don't-or." - C. De Vries [more]
Unread 17-01-2006, 19:32
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Powering CMUcam without full-size RC?
I'm taking the CMUcam home tonight for some testing. While I've been at our school, I've been using the '04 robot to power the CMUcam. However, I obviously can't bring the whole robot home to test the camera. Will the camera be able to be powered off a Robovation PWM port? If not, is there any other way to power it without a full size controller?
Thanks.
http://www.mikesorrenti.com/
Unread 17-01-2006, 19:46
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Powering CMUcam without full-size RC?
Yes, the EDU-RC works fine (the code was developed on a EDU-RC).
-Kevin
Edit: Er, wait, I just remembered that I modified the CMUcam2 attached to my EDU-RC to derive it's internal +5v from the EDU-RC's +5v supply. So, I'm not sure if the +7.2v is available on the PWM outputs.
Kevin Watson
http://kevin.org
Unread 17-01-2006, 22:07
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
-Kevin
I simply use a 9 volt power supply I had laying around from some old device. Radio Shack, etc. has the male versions of those power plugs available to accept soldered wires.
If you happed to have old "brick" transformer power supplies laying around, they can come in handy for easy, (more) portable power.
Cheers!
-Joe
Unread 17-01-2006, 22:56
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
-Kevin
Yeah, the EDU-RC works OK to provide power through the PWM output. For the demo unit that I used during the kick-off, I used one of the IFI mini-controllers, which is internally nearly identical. On that unit, power was pulled from the "PWM Out" header on the mini-controller and routed to the camera.
-dave
CMUcam setup Ryan Collings Programming 26 13-01-2006 01:00
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Size Of control box rcubes85 Control System 8 18-02-2005 10:22
Robot Controller File Size Limit ?? RoboGeek Programming 1 17-01-2005 19:59
What size is it? sburro Motors 3 19-11-2004 19:38
