Go to Post Mentor to Student: "It's OK, if you mess it up you just get to do it again." - EStokely [more]
Unread 13-01-2006, 23:27
ryan_f ryan_f is offline
ryan_f is an unknown quantity at this point
Servos controlling camera and purple screen
We are having two problems with our camera. We aren't exactly sure how to get the servo motors to move so the camera can track a target. Our camera is able to track targets fine with labview but there's just no movement in the servos. We connected them to pwm01 and pwm02 and used the default 2006 camera code.
Our other problem is when we load the settings for the camera to track the green lights. when we click "grab frame", the image comes out completely purple. If we load the default settings for the camera then the picture comes out fine.
Any ideas?
Unread 13-01-2006, 23:34
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Re: Servos controlling camera and purple screen
If you want LabView to be able to track the green light, you will need to use the servo outputs on the camera instead of sticking them into pwm01, and pwm02. There is however the question if this is legal with the rules, as currently that is unknown.
My Blog!
Unread 14-01-2006, 18:21
buss buss is offline
AKA: Steven
FRC #0180 (S.P.A.M. Robotics)
buss has a spectacular aura aboutbuss has a spectacular aura about
Send a message via AIM to buss
I found that the screen will be purple unless you calibrate in RGB mode, and then calibrate in YCrCb mode. That worked for us, anyway.
Steven Buss
"Far and away the best prize that life offers is the chance to work hard at work worth doing."
-- Teddy Roosevelt
Unread 16-01-2006, 20:43
Using the supplied calibration and YCrCb mode, the camera view does seem completely purple, but bright fluorescent lights can be seen as a somewhat reddish purple, and the green target will actually appear as a faint bit of bluish purple.
That bluish purple is easily tracked by the camera against the less bluish purple background.
Unread 16-01-2006, 22:51
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
We were trying to figure out what to do with the purple screen in LabVIEW today, until I clicked on a random part of a frame grab taken when pointing at the green target. The selection area showed up on the outside with an un-highlighted section where the green light box was. Clicking in this area reversed the selection highlighting. I could not even see the difference on the laptop screeen (with highlighting turned off), so you may not be able to notice a difference either. However, the camera can certainly detect the difference and now tracks perfectly.
Also, we still hade problems with slight detections of other lights. The noise filter was not working well enough, so I corrected this by modifying
if(T_Packet_Data.my != 0)
to
if(T_Packet_Data.my != 0 && T_Packet_Data.pixels > 10)
in tracking.c
Just wanted to let others know how to easily correct this problem in the default code.
FRC Volunteer, FLL regional planning committee member for Colorado
Former Programmer, Web Designer, Communications Director of Alpine Robotics Team 159.
Add your team to the FIRST Teams Google Map
Unread 17-01-2006, 01:34
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
to
in tracking.c
The purple screen is due to a bug in the LabVIEW code for the camera which has the picture that is displayed interpret the YCrCb data as RGB data. The conversion ends up being "all purple" -> "all black". Fixed it up last weekend and will post it tomorrow when I get to work. It should be easier to see dark gray on black than purple on slightly darker purple. Besides, it's just ugly to look at.
Sorry for the delay on getting it posted. We are trying to get a site approved to host the VIs that everyone can get to. Some people have restrictions getting to FTP sites.
For you kids out there who are interested in what that problem is and how you can fix it, Google for "YUV RGB conversion" or "YCrCb RGB conversion". You'll find plenty of information about it. You can then try fixing it in the version you have by implementing the 3 equations. You can also download the fix tomorrow and see how I chose to implement it. Consider it a challenge. Play around with LabVIEW and you'll see just how powerful and easy to use it really is.
Best of luck!
-Joe
Unread 17-01-2006, 23:21
AKA: jhersh
OK... the new version is posted here. It supports a few new features and the purple bug fix. Read about it and enjoy.
Cheers!
-Joe
BTW, did anyone look at the problem to see if they could solve it?
