Go to Post Who am I kidding, FIRST is so much cooler now than it was when I was a youngin'! - Michael Corsetto [more]
Unread 18-01-2006, 00:42
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Belt For Fisher Price Motor
Originally Posted by lupjohn
Check online to find your local Gates Rubber Power transmission products dealer. The belt is 15mm wide with a 3mm pitch and comes in a number of circumferences ( read belt length) measured in mm. I needed a belt approximately 300mm in length. They also sell the matching sprockets for the driven end of your belted drive train again with 15mm width and 3mm pitch. The motor sprocket is 16 tooth so any multiple of 16 gives the desired gear reduction ratio. I.E. 16:48 is 1:4 reduction ratio. I ordered my locally through Motion Industries and will take 5-7working days for delivery. Hope this helps out. Best wishes, LRU.
I believe you're referring to the CIM motor. The FP motor comes with a gear, not pulley on it's output shaft.
Furthermore, I don't even see a motor with the model number that the original post references.
2001-2004: Team 100
2006-Present: Team 254
Inductance of CIMs phrontist Electrical 13 06-01-2006 09:17
Cheap Torque Measurement? ChuckDickerson Motors 15 13-06-2005 13:57
**FIRST EMAIL**/Important Fisher-Price motor and gearbox information sanddrag FIRST E-Mail Blast Archive 1 11-02-2005 18:19
Use of the fisher price motor ALONE Some Guy Motors 6 03-02-2005 08:55
Fisher Price Motor Into Drill Gearbox Chris Technical Discussion 11 21-04-2004 09:09
